A bunch of CEL's, what could it be?
Old Jan 24, 2010 | 04:21 PM
Infowire's Avatar
So i been having these cel's on for like past 4 months, just getting around to doing them... anyone have a clue where i should start?
P0130 - o2 Sensor Circuit
P0135 - o2 Sesnor Heater Circuit
P0155 - o2 Sesnor Heater Circuit
P0325 - Knock Sesnor 1 Circuit
i also used to have this code when i first scanned my car 4 months ago..
it is gone now... but i didn't do anything:
P0400 - Exhaust Gas Recirculation Flow
this is usually egr related....
Old Jan 24, 2010 | 06:24 PM
Dhione's Avatar
bro I would start with the O2 sensors then see where that gets you. has the car been getting bad on gas lately?
Old Jan 24, 2010 | 06:31 PM
Infowire's Avatar
yeah i get 30 miles less than usual. the o2 sensor has been replaced and so has the knock sensor.
Old Jan 24, 2010 | 06:37 PM
Dhione's Avatar
what O2 sensors did you repalce them with and which O2 sensors did you change? did you get the plug in ones or the ones that you have to splice wires?
Old Jan 24, 2010 | 06:56 PM
Infowire's Avatar
i replaced the one that is closest to the front of the car since that was the one that wasn't showing any data on the comp, and i got the o2 sensors that i had to splice.
Old Jan 24, 2010 | 07:24 PM
internetautomar's Avatar
mod or sell?
double check your connections on the splice.
did you replace the harness when you replaced the KS?
Old Jan 24, 2010 | 07:54 PM
defiance's Avatar
Plug and play FTW ! The only things I would ever splice are Speakers...
Old Jan 24, 2010 | 08:06 PM
Infowire's Avatar
i had a shop do it for me.. since they owed me.
Old Jan 25, 2010 | 11:32 AM
cashoit's Avatar
02 sensors arent hard tho. shouldnt be a problem. After replacing did u reset ECU.
Old Jan 25, 2010 | 11:39 AM
Infowire's Avatar
yes i reset the ecu. We had a snapOn obd2 computer, we tested the sensors made sure they were showing data.
Old Jan 25, 2010 | 01:32 PM
smai555's Avatar
do u know the brand of 02 sensors?
i would check that harness and spice of the front 02 sensor
the harness for it is between the radiator fan and slave cylinder( manual tranny) or in that area
the harness for the left bank is near the firewall pass. side on a bracket ill see if i can find pictures of both for you
from what i have read it maybe just be loose causing the CEL to come on
or low quality 02s
Old Jan 25, 2010 | 03:24 PM
Infowire's Avatar
i think they are bosh, or whatever napa sells.
Old Jan 25, 2010 | 04:05 PM
MaximusPrime425's Avatar
Are O2 sensors a DIY job? If i have a jack and a new O2 sensor and tools, then I can pretty much get it done by myself right? or would a shop have to do this....
Old Jan 25, 2010 | 07:10 PM
smai555's Avatar
way to hi-jack the thread
i did mine myself i got a 02 wrench from autozone it was a life saver and youll need pb blaster or some sort of penetrating oil
Old Jan 25, 2010 | 07:12 PM
Infowire's Avatar
you can do it yourself it easy.... they might be rusted into the pipe tho... might need to heat or something...
Old Jan 25, 2010 | 07:13 PM
Infowire's Avatar
Now to hijack my thread back, im go read computer data again tomorrow... see what the sensors say.
My buddy says aftermarket knock sensor might cause issues... ? but i dont think so
Old Jan 26, 2010 | 07:51 AM
mod or sell?
not likely.
2 of your codes are heater errors. that is not a code that a KS can cause.
Old Jan 26, 2010 | 12:53 PM
FallenOne's Avatar
That KS code is most likely a Ghost code, your 02 wiring is either wrong or the sensors are bad. gonna say wiring though.
litch
123
Jan 4, 2024 07:01 PM
jmlee44
Oct 2, 2022 02:13 PM
MaxDD
Sep 24, 2015 06:40 AM
JoshG
51
Sep 21, 2015 10:41 PM
