ECU upgrade for 98
Old Dec 5, 2001 | 01:01 PM
Tai Mai Shu's Avatar
ECU upgrade for 98
I know they have someone that does ECU upgrades for the 97, but what is the difference between them? i though it was the 96 and the 97, and any info about an ECU for the 98?
Old Dec 5, 2001 | 01:43 PM
straight six's Avatar
Re: ECU upgrade for 98
JWT created an ECU designed for 95-96 Maximas. It has been known to work on the 97 Maxima as well but w/a few MIL codes. There is no ECU for 98+ Maximas other than the Jet Chip which some say gives no gains and is a piggyback unit not a stand-alone ECU.
Old Dec 5, 2001 | 03:12 PM
MegaMax's Avatar
Poison
Improving horsepower by as much as 25%
through the range of approximately 1,000 -
5,000 RPM. The Venom400 is OBD II
compatible. Besides substantial increase
of torque, the Venom400 reduces the flat spots
or delay timing during sudden accelerations.
Incorporated into the Venom400 is an 8-bit micro-
controller that is capable of monitoring the
various sensor inputs and modifying their
outputs at more than 40 times per second.
If you already have another performance
prom installed not to worry the venom400 is
a mid range performance chip and the prom
chip is a wide open throttle application thus
complementing each other through the entire
RPM band.
The Venom400 has an on/off switch so smog
certification is possible without detection of unit.
Easy installation with basic hand tools requiring
only four electrical connections.
Loss of gas mileage to be expected
is 1-3 miles per gallon in fuel economy.
No significant damage or long term
stress side effects in long and short range
testing.
To read more go to: http://www.venom-performance.com/
Old Dec 5, 2001 | 03:19 PM
mitch33x's Avatar
Venom400
does anyone with a 97-98 have this?
Old Dec 5, 2001 | 03:21 PM
MegaMax's Avatar
Re: Venom400
I'm going to get it for the car's X-mass Gift.!!!
She was good and never gave us problems all year.
Old Dec 5, 2001 | 03:31 PM
mitch33x's Avatar
Re: Re: Venom400
......maybe this will actually produce good gains for 97+, cant wait to see what it can do
Old Dec 15, 2001 | 05:36 PM
Blade_99SE's Avatar
Re: Re: Venom400
Don't waste your money on the venom 400. All it does from what i hear is advance the Throttle Pos Sensor. In other word it makes the car think you are pressing on the gas harder than you are. BTW the limit is full throttle. In other word when you are flooring the car the vemon400 doesn't work since the car is already floored. This product is snake oil. Don't waste your money. If you don't believe me then do a search on the topic. This has been discussed about 1.5 yrs ago.
Later
Blade
Old Dec 15, 2001 | 09:09 PM
BRIGBOY's Avatar
Re: Poison
RPM band.
testing.
Any dyno #'s??? Or is that from the site. I'm not knockin it cause I aint tried it. Juss wanna know If its worth the loot>
gigabyte
Jan 6, 2017 06:05 PM
Fbana41
Aug 29, 2016 12:18 PM
BLACKKILA.GTR
Sep 29, 2015 11:23 AM
Kyle Lee Cleveland
Sep 28, 2015 09:03 AM
