How do I remove double side 3M tape
Old Feb 4, 2010 | 03:37 PM
_buddha's Avatar
The previous owner of my maxima put in these gay woodgrain interior trim from eBay:
http://cgi.ebay.ca/NISSAN-MAXIMA-199...item2c52efc503
well it looked fine in te beginning except now they are starting to tear and look ugly due to sun exposure, how do I get rid of this crap? Anyone remove 3M tape before from the interior? Will it leave a mark or should I just buy new interior?
Old Feb 4, 2010 | 03:46 PM
CRK's Avatar
CRK
a hair dryer/heat gun, plastic putty knife/credit card and some wd-40 are your friends.... go SLOWLY!! it will come off.. if you hurry your going to scratch something..
Old Feb 4, 2010 | 03:59 PM
_buddha's Avatar
that sounds like a huge hassle, might just get some new parts off another car. Btw how hard is it to remove and install these ?
Old Feb 4, 2010 | 04:29 PM
Mistertones's Avatar
Ronsonol Lighter Fluid works well for removing stuff like that.
Old Feb 4, 2010 | 06:54 PM
JSMax's Avatar
Sold
for removing the adhesive stuff left after you peel off the actual tape... yes... the lighter fluid works just fine.
also, you could try goo gone. you won't have to worry about staining the interior.
Old Feb 4, 2010 | 07:36 PM
Papa Yams's Avatar
removing glue residue
Another thing you can use to remove a lot of gooey stuff is Murphy's Oil Soap. This stuff is made from a vegetable product and won't stain, mark or deteriorate plastic or vinyl.
Added bonus - the Murphy's Oil Soap KICKS *** on tree sap. I had a bad case of pine tree sap in my wife's Mercedes. Tried all kinds of stuff and then used the Murphy's - gone in no time! Doesn't remove the wax from the paint either.
Old Feb 5, 2010 | 02:58 PM
smai555's Avatar
or you can polish them... use the a headlight polishing kit or check the detailing section of the forum
Old Feb 6, 2010 | 05:49 PM
_buddha's Avatar
polish what? if ur talking bout the dash kit that im trying to remove, polishing it will do nothing
Old Feb 6, 2010 | 06:39 PM
smai555's Avatar
you can polish out the fading and light scratches but if its chipping and cracked then yea replace it or remove it i have never remove but im guessing its just plastic pieces that are taped on and as everyone above me said use a heat gun and or goo gone/ rubbing alcohol
i guess i was just trying to give another option
or after removing it and it does leave a mark you can polish them out
Old Feb 6, 2010 | 06:52 PM
808s96SE's Avatar
there are all kinds of adhesive removers out there. http://www.google.com/products?hl=en...ed=0CDkQrQQwAg
Old Feb 6, 2010 | 07:08 PM
bigpopaj369's Avatar
whatever u do use, keep in mind a little heat will go along way
Old Feb 6, 2010 | 07:15 PM
maxfever1987's Avatar
a blow dryer is your best bet, pry it off slowly and you will see how eell the blow dryer works
Old Feb 11, 2010 | 12:43 PM
saylee's Avatar
at work i use pro-sol to take off gunk like that, like really bad build up... I shaved my emblems in the back and had the left over residue from the molding but when i used the pro-sol, it took it off really easy.. you can find it at the store, the one i use is called PRO-SOL Bug/Tar remover.. its non-flammable also...
The Frye
Sep 2, 2021 11:03 AM
Mar 12, 2020 12:06 AM
Dennis Twohy
Oct 1, 2015 06:01 PM
nissan99
Sep 11, 2015 03:52 AM
Colossus
Sep 9, 2015 05:46 AM
