Ultimate Light Setups thread
Old Feb 20, 2010 | 08:22 PM
  #81
maxprivate's Avatar
Black Lion
Originally Posted by Flava_24/7
I hear ya, I was just stating that. For a while many claimed the CE had them specially made for them, which was BS. They were being imported by them as well as many other companies.
CE is is a rip off! you see how much they have the r34's listed for? Their customer service is also terrible, speaking from my personal experience.
Old Feb 20, 2010 | 08:24 PM
  #82
nalc's Avatar
Flava, what headlights are those?
They look like the 95-96 parabolics, but you have clear lenses on them, and I know the 97-99 lenses won't fit on the 95-96 reflectors. CE/ebay glass lenses on 95-96 parabolics?
Old Feb 20, 2010 | 08:25 PM
  #83
Flava_24/7's Avatar
Boosted Panda
Trust me, I know this. CE has always been $$, but back when Greg owned it the CS wasnt so bad.
I refuse to buy parts from there. No need to really.
Old Feb 20, 2010 | 08:27 PM
  #84
Flava_24/7's Avatar
Boosted Panda
They are the 95-96 glass lensed headlights, and your right... the lenses will not fit on the 97-99 housings.
95-96 lenses are flat as the 97-99s are curved.
Old Feb 20, 2010 | 08:31 PM
  #85
nalc's Avatar
Then they gotta be those ebay glass lenses. Because 95-96 glass is fluted, and your glass is clear.
Old Feb 20, 2010 | 08:37 PM
  #86
Flava_24/7's Avatar
Boosted Panda
Yes, they are. The clear glassed lenses on ebay are modeled after the 95-96 headlights.
The OEM 95-96 glass headlights are the fluted ones.
Trust me, when I bought the 95-96 clear glass lensed headlights I tried to put the lenses on my retroed 97-99 oem plastic lensed headlights and made the discovery of the different shapes.
Old Feb 20, 2010 | 08:47 PM
  #87
nalc's Avatar
yup... the 97-99 lens is curved on both sides, but the 95-96 is straight on the inside and curved on the outside.
Looked at the ebay auction, though, and the ebay clear glass ones are cut like the 95-96s.
So you had OEM 97-99 headlights retrofitted, but then switched to OEM 95-96 reflectors and aftermarket clear glass? Sounds complicated
Old Feb 20, 2010 | 08:54 PM
  #88
Flava_24/7's Avatar
Boosted Panda
No, I had a early set of 97-99 headlights retrofitted by Maxgtr.
When I saw the release of the 95-96 clear "glass" lenses I had to have them No need to sand and polish. After I bought them, I tried to swap the lenses over to my exhisting retrofit. When they didnt fit, I said F-it and did my own retrofit onto the newly purchased 95-96 housings.
Like I said, I bought two sets of those. One housed my old transfered setup and the second set was for my current setup. My current setup took FOREVER.
First, because I was in no rush since I was already using a retrofit and second I was the first to do a dual projector setup in a OEM styled housing so I was very patient about making it fit and look nice doing so. It also took me a bit to find all the parts to make it work. Im still the only one to have done so to this day as far as I know of.
Old Feb 21, 2010 | 05:56 AM
  #89
Eyce's Avatar
CE didnt make them, just the first to introduce them. A week later they were all over Ebay for around 110.00 shipped. I bought two sets back then.
They can still be found on Ebay
http://cgi.ebay.com/ebaymotors/ws/eB...K%3AMEWAX%3AIT
I don't suppose you might know of a set of corners that would match those headlights? I've searched ebay numerous times for a set of euro headlights like those and corners to match and came up empty...I fail.
Old Feb 21, 2010 | 08:52 AM
  #90
IlyaK's Avatar
The Golden One
Originally Posted by michaele30
Hey...the lights looks sick....just a correction, the "e36 shrouds" I am assuming you are describing the chrome around the project itself......but yours are DEF NOT e36, they are e46 which is a 2002-05 3-series low beam projector shrouds, may also be found on some e46s going back to 2000.
Just thought it would help anyone else looking to do a similar mod.
Just my 02 cents (bimmer nut here)
You are correct. That was a typo.
If we are going to get technical, those headlights are not OEM. None of the 4ths gens ever had an OEM clear glass lens. I think those were made by like Custom Maxima or Custom Enterprise or one of those aftermarket companies.
You can also tell by the lack of horizontal ridges, and the curves in the bottom inner corner.
However, those headlights are better than OEM. Probably the best candidate available for a bi-xenon retrofit. I like my R34s, but I have a quad setup.
By OEM I meant stock...I guess I should have said OE? They are definitely better than the stock lights, but these were purchased on EBay.
Old Feb 21, 2010 | 09:00 AM
  #91
9t8alti's Avatar
R34s with a Bixenon retrofit kit with CCFL halo and LED strips from Advance Auto and this is my first set of lights i have done they were very easy to do with the kit no cutting of the light was required.
  #92
9t8alti's Avatar
Old Feb 21, 2010 | 10:28 AM
  #93
C-ko's Avatar
Hey Flava, do u happen to know if the clear euro corners that were released with these headlights are still available? I've been looking for a pair for a long while now lol. Thanks.
Old Feb 21, 2010 | 10:31 AM
  #94
Flava_24/7's Avatar
Boosted Panda
Havent seen them around in a while.
Old Feb 21, 2010 | 11:52 AM
  #95
DIAMONDS98SE's Avatar
So how much for a set sent to 80020? Damn those look sweet
Old Feb 21, 2010 | 12:03 PM
  #96
nalc's Avatar
go to hidplanet and find a member named stupidpig
he has a factory connection for those
Old Feb 21, 2010 | 09:45 PM
  #97
_buddha's Avatar
wow Ilyak you have the nicest light setup i've ever seen !!
Old Feb 22, 2010 | 05:43 AM
  #98
IlyaK's Avatar
The Golden One
Well thanks. I think a couple of other guys have better, but I appreciate the compliment.
Old Feb 23, 2010 | 05:46 AM
  #99
kiecas17's Avatar
So this thread is telling me that if I want cool lights I have to make them myself?
Old Feb 23, 2010 | 05:59 AM
  #100
Flava_24/7's Avatar
Boosted Panda
UH, No. of you want good output meaning effective lighting then you have to make them yourself since the current 9004 setup Nissan used BLOWS.
The R34's look nice, but have horrible out, HIDs in reflective housings are a complete waste of money which leaves projectors, ie a retrofit.
Old Feb 23, 2010 | 07:31 AM
  #101
nalc's Avatar
It's not uncommon to see HID projector retrofits come up for sale.
Old Feb 23, 2010 | 08:08 AM
  #102
IlyaK's Avatar
The Golden One
Or you can contact a retrofitter like gtr_rider and pay him to do it for you (see my retrofit).
Old Feb 23, 2010 | 12:36 PM
  #103
hottsauce2864's Avatar
can the led altezza lights you know the one with the rings on ebay they say 97-99 maxima i was wondering if anyway they can fit on a 96
Old Feb 23, 2010 | 01:05 PM
  #104
nalc's Avatar
negative.
Old Feb 23, 2010 | 01:13 PM
  #105
that sucks and im looking to buy new headlights can sum1 send me a link of the best ones to get i like the black ones send me the links where u got urs
Old Feb 23, 2010 | 01:21 PM
  #106
Coolsaber57's Avatar
Well...you could always do a 97 trunklid swap.
Then again, I would never condone the use of altezzas. Ever.
Old Feb 23, 2010 | 01:31 PM
  #107
JNCoRacer's Avatar
Just the tip.
EVER.
Old Feb 23, 2010 | 02:11 PM
  #108
maxprivate's Avatar
Black Lion
I think the Gen 2 alteza led tails look nice, but only with the smoked lens and on dark cars.
FYI for people out there. You CAN do your own retro; that is if you have the time and money. It also requires lots of time and patience and reading up on info to do them. First of all you will need a Dremel for cutting up the housing of our headlight of choice. You will also need to decide what projectors and shrouds to go with. You will need a wire harness to make it all work. The info is out there. Just a little encouragement for those contemplating on doing a retro. I did mine with no experience at all.
Old Feb 27, 2010 | 02:48 PM
  #109
NYC A32's Avatar
Heres mines....Thinking about switching it up tho.
R34s with FX35 projectors & clear lens mod paired with TSX projectors.
GTI replica shrouds with LEDS in them (i try going for the iron man look, but failed because the top and bottom clearance).
I'll post more better pics from the guys who built this for me once I get on my pc.
Old Feb 27, 2010 | 08:31 PM
  #110
maxprivate's Avatar
Black Lion
Cool idea, looks good. It will suck if those leds in there ever go bad though. Ask me why I would bring this to your attention.
Old Feb 27, 2010 | 09:00 PM
  #111
anomaly117's Avatar
my old sig, nothing special, simple and sweet. just thought i'd contribute.
Old Feb 27, 2010 | 11:33 PM
  #112
C-ko's Avatar
Yup, I agree. Remember when they brought back the cefiro style emblem last year? Yea, those def. were nothing close to replicas. They were something more like cardboard stickers lol.
When they were finally manufactured, they had the audacity to send them to the customers that pre-paid for the emblems, including me, without letting us know of the disappointing outcome.
Never again!!!!
Old Feb 28, 2010 | 05:55 AM
  #113
NYC A32's Avatar
Thanks. Well I've been driving over a year with them so far, and thank god it didn't burn out yet. Esp from all the heat the porjectors throw out I would think they would burn out faster. If they do blow out I really don't mind because I want to do something diff with the bezel and projectors.
Just in case anyone wondering why get four projectors when 2 is good enough? Well just brighter then hell and I have a switch so if I'm driving with one on and they blow I'll just flip the switch and the others will go on. Also I drive mainly at night so lighting is pretty important esp during winter driving and heavy down pours.
Old Feb 28, 2010 | 03:54 PM
  #114
kiecas17's Avatar
I don't really care too much about the output, I just like the looks of the projectors.
Thanks for the info, I will probably contact one of these guys once I get some money for HID projectors, looks sick on Maximas
Old Feb 28, 2010 | 04:02 PM
  #115
kiecas17's Avatar
First post: 1999 Nissan Maxima se
sorry werid post
Old Feb 28, 2010 | 05:40 PM
  #116
maxprivate's Avatar
Black Lion
Have you noticed any discoloration of your E46 shrouds? The chrome finish on mine are turning a bit yellowish compared to my E90 shrouds (for the DRL) that are still a nice shiny chrome. Im wondering if they are fake or replicas now, dam ebay auction stated the were authentic and they have the XENON logo which the replicas do not.
Old Feb 28, 2010 | 07:11 PM
  #117
IlyaK's Avatar
The Golden One
Nope. I'll have to take a closer look but as far as I know mine are doing good.
Old Feb 28, 2010 | 08:07 PM
  #118
maxprivate's Avatar
Black Lion
Im just going to replace them with something else, the difference in chrome finish is killing me. Spent so much damn money on shrouds already.
Old Feb 28, 2010 | 10:09 PM
  #119
MAX/GTR's Avatar
Old Feb 28, 2010 | 10:27 PM
  #120
EsQueue's Avatar
Probably the worst looking ones here but I love 'em.
Aftermarket cefiro headlights, e46 bi-xenon projectors with an ebay shroud, h3 3000k fogs, moded corner lights to turn on with the fogs. I also made a custom harness to power the headlights.
Daytime shot
Headlights only
Fogs + corners only
Both
