95 Maxima CYL 1 will NOT fire. Please help, need car!
Old Feb 18, 2010 | 07:24 AM
ls1forlife's Avatar
Hello,
I have a 95 maxima with 79k. it ran amazing until this morning. cyl 1 will not fire. replaced coil with brand new. Still will not fire. Plugged cyl 3 harness into "bad" cyl 1 coil, and it fired the coil. I use a test light and it lights up the red wire, with the ignition on. im going to search this forum, i need the car! please help!
thank you
Old Feb 18, 2010 | 07:25 AM
ls1forlife's Avatar
it does have a code for the knock sensor p0325, but i think its because its knocking due to a dead cyl
Old Feb 18, 2010 | 07:50 AM
cashoit's Avatar
Well if u plugged cylinder 3 harness into coil 1 and it fired then that means that cyl 1 harness is busted. Jus clip the wires and rewire or hit the JY or parts store for another coil harness
Old Feb 18, 2010 | 07:52 AM
ls1forlife's Avatar
is the harness being busted a common thing? should i just go to the JY and pull a cut a new harness and splice it on?
if the cyl1 injector was shot, the coil would still fire right? i pulled the coil and plug out and started it, and the plug did NOT fire.
Old Feb 18, 2010 | 08:07 AM
cashoit's Avatar
It sounds like to me that u are not getting signal to that harness. If u have already replaced the cyl 1 coil (with a NEW one) and the plug still does not fire that its an electrical issue. Meaning a wire shorted out somewhere. I would proceed to the harness and check resistance across the terminals for a short. See if u can rewire it. If that dont work then the wire shorted out somewhere. If that is the case then your best bet would be to trace that wire back to the origin, clip, and re-wire
The injector should be fine.
Old Feb 18, 2010 | 08:10 AM
cashoit's Avatar
or get one from the JY like u suggested and jus splice it in.
Old Feb 18, 2010 | 08:15 AM
ls1forlife's Avatar
thank you, im checking the harness and condenser now.
Old Feb 18, 2010 | 08:45 AM
ls1forlife's Avatar
condenser has no resistance
Old Feb 18, 2010 | 12:55 PM
cashoit's Avatar
infinity means a open circuit or short
Old Feb 18, 2010 | 03:33 PM
ls1forlife's Avatar
had no resistance. got a new condenser, it fired, now go fuel. pulled the upper manifold, injector was shot too. no resistance either. should be back together tomorrow. thanks a lot of your help
Old Feb 19, 2010 | 10:12 AM
cashoit's Avatar
ok man..let us kno how it goes. Sounds like u on the right track
Old Feb 19, 2010 | 02:09 PM
ls1forlife's Avatar
bought a inject from AZ for 80$ 800-1149N, cant get it to fit seat....
Old Feb 19, 2010 | 04:27 PM
ls1forlife's Avatar
put a lil oil on there and tapped her in, no problem. about to put on the uim, but i cant figure out where the 1 vacuum line goes on the back bottom of it(back at the fire wall driver's side T fitting)
Old Feb 19, 2010 | 04:35 PM
ls1forlife's Avatar
i love this forum, just searched and found pictures of what i need to know!! great!!
Lakersallday24
Jun 16, 2019 01:35 AM
Quickgtp
Apr 13, 2017 03:30 PM
acw
Aug 13, 2015 12:50 AM
MikesChevelle
Aug 6, 2015 11:36 AM
halfpol
Aug 5, 2015 08:24 PM
