Planned rear valve cover gasket replacement - question
Old Feb 23, 2010 | 08:31 AM
edwardh1's Avatar
99 max- If I have the rear valve cover gasket replaced, does it in any way involve draining coolant?
have some Nissan OE coolant i would then give to the mechanic.
I dont like dexcool.
Old Feb 23, 2010 | 08:35 AM
JNCoRacer's Avatar
Just the tip.
Nope. But if you have coolant and its been a while since your cars had a flush and fill, then go ahead and do it. Otherwise, you dont have to mess with the coolant to change the rear valve cover gasket.
Old Feb 23, 2010 | 08:36 AM
NISSANMAXIMA91's Avatar
nope. may loose a tiny bit from the TB, but no. you don't need to drain it.
Old Feb 23, 2010 | 09:09 AM
edwardh1's Avatar
Thanks!!
thanks
didn ot want them to mix
anyone had a private garage do a rear valve cover gasket replacement- how many shop labor hours??
Old Feb 23, 2010 | 10:06 AM
dan1el's Avatar
Originally Posted by edwardh1
thanks
I just got my first tool set in Nov 2009 and did it myself in about 4 hours. In my experience I would not pay a mechanic to do it. There is an awesome writeup on removing UIM here
http://forums.maxima.org/4th-generat...im-w-pics.html
That's the only thing that makes this job take more then 30 minutes. Follow the steps and do it yourself in my opinion.
Old Feb 24, 2010 | 01:40 AM
dragonboyokada's Avatar
Just don't forget to reconnect the rear coolant line like I did. I also replaced the factory hose clamp on it with a screw type that you can get from any hardware store. It's tight back there so it makes future servicing and installation much easier.
I have a thread on my UIM and valve cover gaskets misadventure if you do a search. Otherwise plan on 3-4 hours and take your time. Definitely a DIY job.
Good Luck!
Huttig2009
Sep 25, 2015 03:31 PM
MAXSE5SPD
Aug 23, 2015 12:06 PM
MaximaDrvr
Aug 19, 2015 08:20 PM
doobadoo
Aug 15, 2015 06:43 PM
Nintensity
Aug 13, 2015 05:41 PM
