HELP! Removing Silencer
Old Feb 26, 2010 | 12:03 PM
Cmaxima's Avatar
I've done some searching on the org and google and every idea I've come across has failed me so far. I just put on the custom cat-back from custommaxima.com and everything went great except I can't remove the silencer. The 2 bolts holding it down have been taken off I've tried spraying it with PB blaster, and removing it while its warm so the metal expands. No luck. The silencer looks like it goes back about 6 inches so I need something almost like a hook tool to get a hold of it and slip it out. If anyone has conquored this problem, knows a tool that will help me or anything it would be a life saver, messing with this exhaust for the past 3 hours is getting irritating.
Old Feb 26, 2010 | 12:12 PM
Quickywd01's Avatar
You mean the resonator? Spray wd-40 on the rubber hangers and try to get some inside where the metal hanger goes into the rubber and then move it around and you can use a big flat screw driver to help. On the bolts, spray them with pb blaster, heat with a propane torch and then remove.
Old Feb 26, 2010 | 01:15 PM
Cmaxima's Avatar
no the entire system has been installed already, its not the resonator, its the silencer on the end of the muffler. It looks like this
http://forums.maxima.org/group-deals...-159-99-a.html
this is the exact system i ordered.
Old Feb 26, 2010 | 01:55 PM
ajm8127's Avatar
Grab it with pliers, it can be stubborn. It's too loud without it in my opinion though.
Maybe use two pairs of pliers, gripping on each side of the small inner pipe to equally distribute the force.
Old Feb 26, 2010 | 03:16 PM
ImmaSquashYou's Avatar
you should be able to grab it at the holes where the lil bolts are used to hold the silencer in place. fyi, those lil bolts will come out, use loct-tite if you want them secured
Old Feb 26, 2010 | 03:40 PM
Cmaxima's Avatar
thanks for the advise, Ill probably go at with with some vice-grips when i get home from work tonight, Someone I talked to said i could cut it out, obvisouly this will ruin the silencer but if i cut this part out is there potential to ruin the actuall muffler?
Old Feb 26, 2010 | 05:48 PM
anomaly117's Avatar
vice-lock pliers and elbow grease. and watch your knuckles, i skinned mine good on the driveway when i finally got mine loose.
Old Feb 26, 2010 | 09:25 PM
HandsonMaxima.'s Avatar
you might want to take off the B pipe portion so you dont break something tugging on your exhaust with vice grips. remember to use cloth on the metal so you dont ruin the silencer if you like it better with it on.
Old Feb 27, 2010 | 01:05 AM
carcrazyM01's Avatar
mine has one bolt and it pops of easily but you should try to use a coat hanger make it into a U shape with the ends bent outward slide it into the silencer let it lock on and pull it out..
Old Sep 8, 2014 | 10:21 PM
Brandonmellick95's Avatar
I have a 1998 Nissan maxima with a brand new thrush glasstube muffler with stock tip , were should I be looking for wanting to remove the silencer ? I thought with this new muffler it would be louder but I wasn't to happy with it so now I'm looking for away to make it abit louder . Any help ??
Old Sep 8, 2014 | 10:33 PM
You're not understanding what the OP was referring to. A silencer is installed in the tip of the muffler, as seen here.
Get a ypipe, you'll definitely notice a difference in sound, and a nice little gain in power too. I suppose you could remove the resonator and weld in a straight pipe for more sound... lots of options really.
Old Sep 9, 2014 | 06:48 AM
RealityCheck's Avatar
Hi car
I left mine in because it's too loud. Sounds better IMO with it in. Not obnoxious.
Old Sep 9, 2014 | 02:27 PM
^Hope you at least paint it black...
Old Sep 9, 2014 | 04:57 PM
I did actually! It looks swell.
my03maxima
Jul 28, 2024 07:40 AM
doctorpullit
Mar 29, 2016 11:08 AM
RealityCheck
Oct 2, 2015 06:34 PM
jaydot901
Sep 29, 2015 01:18 PM
Max Nu-BE
Sep 28, 2015 10:25 AM
