Will the motor start..
Old Feb 26, 2010 | 08:14 PM
NoMam's Avatar
will the motor start up with 80 compression all around?
Old Feb 26, 2010 | 08:23 PM
BlueBlackMax's Avatar
how many times did you let it turn over during the test? four times?
Old Feb 26, 2010 | 08:29 PM
NoMam's Avatar
atleast 5, yes
Old Feb 26, 2010 | 08:33 PM
I've never done a compression test on a maxima but Ive done it on other cars. If compression isn't unusually low in any particular cylinder then it should have good compression. If you do get it running a power balance test will help you locate a weak suspected cylinder. Did you test for everything else like fuel and spark?
Old Feb 26, 2010 | 08:38 PM
NoMam's Avatar
one with 30psi, and 5 with 90psi, has spark, and fuel pressure , and sprayed in starter fluid and no start
Old Feb 26, 2010 | 08:50 PM
did you test spark just against the engine block?
Old Feb 26, 2010 | 10:25 PM
NoMam's Avatar
Yes..
AaronL
Aug 8, 2020 10:31 AM
D Mason
Jun 21, 2016 04:43 AM
Unclejunebug
Apr 2, 2016 05:42 AM
knight_yyz
Nov 1, 2015 01:34 PM
