Parasitic Power Drain
Old Feb 28, 2010 | 08:51 PM
jxkim's Avatar
Ever since my dad got in a fender bender (front area damaged) ... basically the front end got smushed in a bit. not to do any frame damage though. but basically popped all those wonderful plastic pieces and bent the hood and bumper
anyways ever since then i have had a real slow power drain. if the car sits for roughly over 24 hours i will need a jump start. now from the little research i've done this is caused by something drawing current when car is OFF. i have no experience with electrics on the max or any car (besides doing my own stereo work)
i am pretty sure this is not an issue with the battery or alternator.
any ideas? i am in North NJ if you know a local person who is good with electric repair work?
Old Feb 28, 2010 | 08:59 PM
cartman854's Avatar
The battery is sending out power (obvious) when the car is off. Go to a local auto electrician and he can probe or check what is drawing power with the car off, this would be the easiest solution, as it is prob a grounding issue in the front near the collision spot. Otherwise you could go cheaper, but could take A LOT longer to fix.
Old Feb 28, 2010 | 10:25 PM
maxi_pad's Avatar
as cartman said its a ground issue. i had a problem like that too.
Old Feb 28, 2010 | 10:54 PM
jxkim's Avatar
can you explain 'ground issue'. there is a loose negative wire somewhere?
Old Mar 1, 2010 | 07:36 AM
cartman854's Avatar
+/- yes, nice tail lights
gigabyte
Jan 6, 2017 06:05 PM
Forge277
Jun 13, 2016 09:26 PM
leatherneck
Sep 30, 2015 09:16 PM
