installed weapon r intake and....
dont know what to do with ait sensor...im hesitant to drill and put it in there..theres no mounting place for it..so i just left it off and figured to check here before i do anything irreversable..runs fine w/o the sensor but CEL is on...what should i do?
what is the sensor for and is it really needed?
thank you for tolerating my "noob-ness" as some call it..
http://forums.maxima.org/4th-generat...mp-sensor.html
I fixed the problem by cutting a small hole in the coupler with some scissors and sticking the sensor in there.
Perfect fit and much easier than drilling a hole in the intake tube itself.
btw this intake sounds way different than any intake ive ever heard...right before it shifts, its just has this very different growl, very unique.the filter also looks badass, very futuristic..ill prob post pics later just bc haha..still dont think its worth $120 tho but too late haha
Sorry, looks exactly like my old Max even tho I know it isnt. LOL
http://i41.photobucket.com/albums/e2...a/SANY1211.jpg
Yeah, well mine looked like yours at one point. I picked up some spray paint at advance autoparts, "Import autospray" made by Duplicolor I think? The can even said Pebble Beige, it was a perfect match. I believe the paint code is CG2? Been a while.
Sensor just makes sure that air is being pulled in. Only sensor that matters is one closer to the TB, if that was not connected, ur engine will turn off, for example if your whole intake shifted off and u started the car, or it was driving when it happened, its not fun, trust me.....
no, his CEL will not go off...pull the codes and tell us what you got.. if its IAT than we can troubleshoot it, it could be bad or a bad connection. if you reset the ECU and the code presents itself again, it obviously has a fault. codes typically do not show until they present upon 3 start ups. thats usually an OK rule of thumb.
MaxLife17
06-27-2019 01:37 PM
Dennis Twohy
10-01-2015 06:01 PM
