Replaced cyl 3 fuel injector now car dies after starting (no idle)
Old Mar 4, 2010 | 02:46 PM
Dexter's Avatar
Hey guys I got the car put back together after replacing the cylinder 3 fuel injector now the car will start but die immediately (no idle). has anyone else run into this problem. I tried holding the accelerator down while starting and it will start for a little bit and then die immediately. Please help!
Old Mar 4, 2010 | 03:01 PM
JNCoRacer's Avatar
Just the tip.
Check your vacuum hoses.
Old Mar 4, 2010 | 03:07 PM
Dexter's Avatar
they are all plugged in, and they were clear of blockage when I was working with them.
Old Mar 4, 2010 | 03:26 PM
Dexter's Avatar
please help guys, I don't know what else to do about it.
note: the car starts but there is no idle and it dies.
Old Mar 4, 2010 | 04:20 PM
Dexter's Avatar
I think I might have flooded the engine trying to crank it the first time. About how long should I wait before trying to crank it again (when gas clears the cylinders)?
Old Mar 4, 2010 | 04:23 PM
Looks like you have to retrace all your steps. Replacing fuel injector #3 required taking off the IM and a bunch of other things along the way.
Old Mar 4, 2010 | 04:29 PM
Dexter's Avatar
yeah, I back tracked everything I took off when I put everything back on, everything is on and I double checked everything before i even tried to turn the car on. Still, car will start then die immediately
Old Mar 4, 2010 | 04:35 PM
Dexter's Avatar
I vaguely remember (this was about 2 years ago) when I cleaned the EGR tube (had to depressurize fuel system for that job as well) that the engine flooded when I tried to start it, so I waited until the next day and it started (don't know why) so I'm kinda hoping that that is the case right now. But if anyone out there is familiar with what is going on any input would be greatly appreciated.
Old Mar 4, 2010 | 04:39 PM
Did you disconnect the MAF for any reason?? Some people claim your symptoms with an unplugged MAF.
OT: Personally, my car starts and idles just fine with the MAF unplugged, it's when I give it gas the car would stall.
Old Mar 4, 2010 | 04:51 PM
JNCoRacer's Avatar
Just the tip.
Have you checked the fuel pump fuse?
Old Mar 4, 2010 | 04:57 PM
Dexter's Avatar
i removed it when depressurizing the fuel system, but I put it back.
Update: just pulled it out again, looks fine (i.e. not blown).
Old Mar 4, 2010 | 04:59 PM
Dexter's Avatar
I did disconnect the MAF. But I plugged all the connectors back in I will check to make sure all the connections are secure though.
Old Mar 4, 2010 | 05:21 PM
Rob_0126's Avatar
i replaced the valve cover gaskets on my 95 close to a year ago. I remember disconnecting A LOT of things.
You might want to look at the writeup for valve cover gaskets, and see if you missed anything.
I did. I missed a vacuum line and caused a myriad of symptoms, until reconnected.
Also mixing up the vacuum lines, I would imagine, might cause some weird problems.
How bout the vacuum lines for the IACV?
Old Mar 4, 2010 | 05:32 PM
Dexter's Avatar
I only disconnected 1 vacuum line for the IACV, I'm going through the UIM guide again to see if I missed anything.
Note: I didn't remove EVERYTHING off the UIM I just removed enough to get it out of the fuel injector's way.
Old Mar 4, 2010 | 07:59 PM
Dexter's Avatar
Well I did a search on the forum and found something similar going on with someone Else's car, it was a grounding issue and was solved by running a grounding wire from the negative terminal to a transmission bolt. I will try that out see if it helps
Old Mar 5, 2010 | 01:17 AM
Nah, that's for the guys where their car cranks and cranks and cranks, and eventually starts and runs. For some, it never starts. Your max starts fine, but then dies quickly.
What year max do you have?
Old Mar 5, 2010 | 08:14 AM
cashoit's Avatar
Sounds like an air issue to me. U sure the IACV is functioning properly. Multimeter is yur friend here
Old Mar 5, 2010 | 09:58 AM
Dexter's Avatar
95 GLE
Old Mar 5, 2010 | 09:59 AM
Dexter's Avatar
I did remove the IACV while removing the UIM, how do I test to see if it is still good?
Old Mar 5, 2010 | 10:45 AM
cashoit's Avatar
U need a multimeter to test for voltage and contiuity.
Check FSM, EC-309
Edit:
YO man...did u remember to check and replace gaskets for TB and IACV and UIM
Old Mar 5, 2010 | 11:48 AM
Dexter's Avatar
Check FSM, EC-309
Edit:
I did replace the UIM gasket, I didn't remove the throttle body from the UIM, but I didn't replace the IACV gasket
Old Mar 8, 2010 | 11:12 AM
Dexter's Avatar
Check FSM, EC-309
Edit:
There is no EC-309 did you mean EC-126?
Old Mar 8, 2010 | 11:15 AM
cashoit's Avatar
I got tha 98 FSM...its EC-309 in there.
Old Mar 28, 2010 | 12:07 PM
Dexter's Avatar
Ok finally managed to pull out the IACV. It's dead as expected. A replacement IACV is not cheap though ($150-$200 ) but at least I know what is keeping my MAX off the street now. Thanks guys for all the help!!
Lakersallday24
Jun 16, 2019 01:35 AM
kjlouis
Nov 24, 2018 06:09 AM
MAXSE5SPD
Aug 23, 2015 12:06 PM
Balkins
Aug 12, 2015 06:39 AM
Maxboy23
Aug 11, 2015 11:59 AM
