Cold Start Problem
Old Mar 11, 2010 | 01:40 PM
Fenton3030's Avatar
Cold Start Problem
I have a 96 with a cold start up prob.
It cranks strong but wont turn over on the first try
2nd try turns over then clunks out
3rd try same thing
4th try turns over then starts to sputter with RPM shaking between 700 and 200
then starts to idle okay but starts self rev'in to around 1200 RPMs then idles back to around 1000
itll drive fine after 2/3 minutes and the start problem wont happen unless the cars not been running for awhile and has cool'd down all the way
itll start fine if i try starting it up again within 30-40 mins after turning it off.
ill give better description of the prob later. running late for work. plz help
Old Mar 11, 2010 | 02:22 PM
luke95gxe's Avatar
3rd try same thing
engine coolant temp sensor (ects) 15 buck at part store 19 mm wrench 5 min swap
Old Mar 11, 2010 | 06:33 PM
Fenton3030's Avatar
you sure thats the prob.im gonna do it but just wondering how you came to that conclusion,
Old Mar 11, 2010 | 07:11 PM
luke95gxe's Avatar
i cant be sure but it happened to me
Old Mar 12, 2010 | 09:53 AM
Fenton3030's Avatar
k. gotcha tell you if that does it
Old Mar 12, 2010 | 10:06 AM
cashoit's Avatar
could be fuel pressure reguator. Its is a check valve that keeps the engine primed with gas so that the car will start with gas in or near injectors. Symptons are: after car has sat for a while the FPR will lose holding cabality and let gas travel back upstream and starve engine of gas. After 2 or 3 cranks the engine has enough gas to turn over.
THe FPR 80 bucks from autozone. It wont set off CEL...its not a sensor.
Old Mar 12, 2010 | 04:32 PM
Fenton3030's Avatar
that sounds more like the problems solution gotta wait a while to check/fix tho at $80
Old Mar 12, 2010 | 04:49 PM
dan1el's Avatar
Cashoit, just wondering why the fuel pressure regulator would only cause problems on cold starts?
OP, do you have any codes? CEL on? Did this happen gradually or one day it just crapped out?
Old Mar 12, 2010 | 05:13 PM
luke95gxe's Avatar
my car had the same issue that u have described i think i have a video of it somewhere when it was cold out my car took 3 4 or 5 times to start then it would run fine ects was my problem but i got no code it cost me 14 bucks at the parts store i think i would go for that part before i throw 80 beans at a fuel pressure regulator
not to discredit u cashoit just saying go for the cheaper part first
Old Mar 12, 2010 | 05:41 PM
Fenton3030's Avatar
it just crapped out on me with no CEL. Im gonna go with the ECTS first.
but the idiot attendant at advance auto parts kept telling me its a dealer part. and i just got aggravated and left. so ill try tomm. early morning before work. how can it be a "dealer part" when i can buy it online from you guys and any other autoparts store. Attendants answer: IDK??
Old Mar 12, 2010 | 06:18 PM
luke95gxe's Avatar
you know what funny i bought mine from advance auto prolly the gut u talked to had no clue what u were talkin bout
Old Mar 13, 2010 | 10:10 AM
Fenton3030's Avatar
most likely lol
Old Mar 14, 2010 | 09:12 AM
Fenton3030's Avatar
Dammit now there's 2 different sizes to the connection openings which one is it 1/8 or 3/32
Old Mar 14, 2010 | 12:04 PM
Fenton3030's Avatar
Okay I put in the new cts and gave it a few minutes after connecting everything I.e the the sensor and battery. TurnEd the ignition and it did the same thing still. I only tried once had to go to work
Old Mar 14, 2010 | 03:39 PM
Trini Boom's Avatar
I have the same problem as you Fenton and after searing numerous times in these forums, I decided to go and order a FPR from the dealer. It does not come with the o-ring and have to purchase separate. The screws the dealer didn't have but I may use something different as I see numerous people say that the head will strip if it was never changed. It is a philip head and I haven't got a chance to replace mine as you know it is a flushout here in the northeast this past weekend so maybe the following weekend.
Old Mar 14, 2010 | 05:26 PM
Fenton3030's Avatar
Cool cool. looking forward to seeing your results Hope it works
Old Mar 14, 2010 | 05:28 PM
Fenton3030's Avatar
Oh and changing the cts didn't seem to make any diff. ...$25 bust :/
Old Mar 14, 2010 | 07:15 PM
Trini Boom's Avatar
Yeah I already went that route myself with the ECTS. Well it is a waste but my car is near the 300K mark so I don't mind starting to change out some of these things since most of the stuff is original.
Old Mar 14, 2010 | 09:17 PM
Fenton3030's Avatar
wow your way up there in mileage hope the FPR is your solution gonna take my car into the mechanic thursday to check it out.
Old Mar 15, 2010 | 08:48 AM
cashoit's Avatar
No prob man. ECTS shd be changed cuz it jus so cheap. U a veteran here too who gives good advice and ECTS could be the problem
FPR causes problems only if the car has been sittin for a couple of hrs. If he starts the car after sitting like 10 min then it shd start right up.
OP,
Gotta do a search for the FPR and Wxm, an org member (think that was his nickname ) . He had same problem as u and he made a write up for replacing FPR.
EDit:
A quick search yeilded the thread i was referring to:
http://forums.maxima.org/4th-generat...?highlight=wxm
Old Mar 15, 2010 | 08:49 AM
cashoit's Avatar
why u purchase from the dealer...u can get the part from autozone like 80 bucks
Old Mar 15, 2010 | 03:18 PM
Trini Boom's Avatar
Well I go to the dealer now since I get a discount everytime I go there which makes the prices slightly higher or lower depending on the part. I paid $93 fromt he dealer for the part versus $125 or any other person.
Old Mar 16, 2010 | 11:41 PM
Fenton3030's Avatar
any update on the FPR fix
Old Mar 17, 2010 | 04:58 AM
Trini Boom's Avatar
I took the day off today to change it. I will post back later today about the changes since its going to be 60 degrees here in NY.
Old Mar 17, 2010 | 05:27 AM
Goomz's Avatar
^ 65 deg 2morrow in jerz ftmfw
Old Mar 17, 2010 | 10:46 AM
Trini Boom's Avatar
Well I just got finished replacing the FPR and as I predicted, stripped one of the screws because it is a philip head... But after I replaced and reconnected back everything, it fired up way faster (2nd turnover vs 6 turnovers previously) and stayed on but now I have a check engine light Checked that I plugged in back everything and I don't feel any rough idling so I have to wait for my friend to bring me my computer to check it.
But I took it for a drive to the dealer because I needed a radiator cap and it drove nicely. Even after getting back in after leaving the dealer, fired up on 1st turnover. I would have to wait and see if it would get back cold enough and test again but the car was never turned on for the day till I replaced the FPR. Will keep you guys posted.
Old Mar 17, 2010 | 11:55 AM
Goomz's Avatar
maybe it needed to start twice to get all the fuel fully pressurized and to the injectors? like a fuel cut switch when started with it activated...fuel runs out of the line and when switched off, it takes just a tad bit longer to start up. maybe the code came on because of this...and does not turn off automatically?
Old Mar 17, 2010 | 03:30 PM
Trini Boom's Avatar
Update: I got the computer from my friend and have 2 codes. P0325 knock sensor which was replaced last summer so I don't understand why that is there and P0110 Intake Air Temperature Sensor. Going to double check that sensor and clear codes. Ordered a new air duct as mine starting to tear apart. With 15 years of age and 297K, things like this would happen.
Old Mar 17, 2010 | 10:26 PM
Goomz's Avatar
damn 297k. im just under 103k...i bought it w 76k. all those miles in less than 10 months.
Old Mar 18, 2010 | 05:51 AM
8ender's Avatar
I wouldn't worry too much. These cars can soak up a ridiculous amount of highway miles.
Old Mar 18, 2010 | 11:46 AM
Justaguy's Avatar
Hi...I have a dumb question...where is the FPR located? Any pics?
I did a search, and after going thru the first 3 pages out of 10, I can't seem to locate it..I also checked the FSM and still can't locate it.. I was searching under "Fuel Pressure Regulator".
Old Mar 18, 2010 | 04:57 PM
Trini Boom's Avatar
That's the FPR which I changed. Have to remove throttle body to get to it and expect to get new screws as I stripped the heads on mine.
Old Mar 18, 2010 | 09:04 PM
Fenton3030's Avatar
Son the FPR was the fix? How's it starting and driving now
Old Mar 19, 2010 | 04:02 AM
Trini Boom's Avatar
Yes the FPR did fix my problem. Even when starting from cold, it starts on the 2nd turnover just as if it was warm. Now I have an intermittent coilpack issue and not sure how I will find out which one it is. Sometimes when I do a warm start, it shakes a bit for like 10 to 15 seconds and then back to normal. Doesn't do it all the time though.
Old Mar 19, 2010 | 01:58 PM
Fenton3030's Avatar
Ok do i have to remove the yellow part too that runs under the intake manifold or just the blue part
Old Mar 19, 2010 | 02:18 PM
Trini Boom's Avatar
Just the blue part. That's why I stated in a previous post that you have to remove the throttle body to get to it.
Old Mar 19, 2010 | 02:24 PM
Fenton3030's Avatar
okay thats not to bad of a task then it seems i just didnt wanna have to mess with the manifold
Old Mar 19, 2010 | 02:30 PM
Trini Boom's Avatar
Its not bad but when you do use a philips screw driver, make sure its a long one that you can apply a heavy force and turn same time because if your heads completely strip, it will be hell to get out especially the bottom one. I had to use three different philip head screw drivers. I am not trying to scare you but prevent the worst.
Old Mar 19, 2010 | 05:09 PM
Fenton3030's Avatar
Thanks alot i appreciate all the help
Old Mar 24, 2010 | 05:45 PM
Trini Boom's Avatar
2ND UPDATE: Well after one week, I guess it was too good to be true but this morning, when I started it it still turned over on the 2nd turn but it turned itself right back off . This is getting ridiculous now.. I need someone to give me a second input on this and I already replaced the ECTS first so if someone had this problem before, please post!
