fog light rewire on my 97 max..
Old Mar 23, 2010 | 10:42 AM
GMAX86's Avatar
how do i rewire wire the foglights to my park lights so that i can have them on with out having my head lights on??
Old Mar 23, 2010 | 11:14 AM
ajm8127's Avatar
Check the how to section. That's how I figured it out.
Old Mar 23, 2010 | 12:37 PM
cashoit's Avatar
+1
U can either power from the battery and install a rocker switch and a fuse to make the fogs totally independent or splice into ur side parking lights. Bear in mind that u might blow the fuse from the extra wattage demand for the fogs.
Old Mar 23, 2010 | 12:48 PM
mas324's Avatar
http://maxima.bryanb.com/fog/fogrewire.html
Simple...
Old Apr 2, 2010 | 12:16 AM
Goomz's Avatar
anyone have any issues with re adjusting their fogs w hid's? i cant seem to get mine to align according to the 25ft wall/4inches under the middle of the lamp's position rule...my output sucks
Old Apr 2, 2010 | 12:47 AM
submaxzero's Avatar
NA Fam its all about how u wire them to the RELAY i did mine work fine plus i took my stock fogs off n connected universal fogs to them work like a charm got pix
Old Apr 2, 2010 | 08:52 AM
sc10692's Avatar
if you splice into the parking lights as long as any lights are on i can have the fogs on rite??
Old Apr 2, 2010 | 11:32 AM
Goomz's Avatar
no man. search the stickies, the write up on how -to is in there.
Old Apr 3, 2010 | 06:22 AM
GMAX86's Avatar
foglights rewire..
i know its kind of late but thanks for the ideas.. i will try the battery and make them independent with a switch.. if it doesnt work out ill just rewire them to my park lights...
Old Apr 3, 2010 | 06:23 AM
GMAX86's Avatar
Old Apr 3, 2010 | 12:08 PM
f550maranello2's Avatar
just wire the trigger to the wiper relay.... 5 minutes and ur done..
Old Apr 3, 2010 | 01:36 PM
MaxiNone's Avatar
where is the OEM fog light switch located? is it on the speedo console like the cruise contol?. on g2ic.com people would connect the power wire to the defroster or hazard lights (which those three switches are next to each other) to have the constant power going when you turn on the fog lights (since the fog lights only turn on when you turn on the headlights). this way when you turn on the fog lights neither the parking or headlights have to be on when you turn on your fogs.
sorry, not to familiar with the interior of a fog light equiped 4th gen and how the fog light switch set up is like or where its at.
Old Apr 3, 2010 | 02:29 PM
AEMAXIMA01's Avatar
It's on the turn signal stalk. If the maxima didn't come with fogs, the stalk wouldn't have the fog switch on it either.
Old Aug 26, 2010 | 06:48 AM
97a32's Avatar
is it the same rewire for a 97 i30?
The Frye
Sep 2, 2021 11:03 AM
fastcarny
Oct 6, 2015 10:42 AM
Dennis Twohy
Oct 1, 2015 06:01 PM
Maxie40
Sep 14, 2015 11:28 AM
-ReLLiK-
Sep 8, 2015 12:02 PM
