Alittle Help with a '99 max :-(
Hello maxers, I have a 99 maxima, with about 140,xxx miles, and the cars giving me some problems.
Lets say i was driving and stopped at a stop light, the problem comes in when i again try to take off. its like the car is trying to take off in 2nd gear. Or like i was driving with a 300-400lb person in the back, but then it would get to normal after i get up to 30-50mph.
I know something crazy happened like this at one point, but then the car would barely want to move and if it stalled, it may have cut off. changing out the KS fixed this problem.
Im just trying to figure out what it could be, im not throwing any codes unless theres some that arent causing the light to go off.
Don't get them NEW from EBay.
Get them USED from EBay. It's no different than getting used on here. I got mine on EBay and have had no problems after going through a bunch trying to fix my misfires.
Could be a TPS issue...but he's saying he has no CEL's so who knows. I remember when I broke the plug on my TPS (my 97 Max) the car would shift like crap. It would go to like 5k and then slam into the next gear. I seriously thought the tranny was done. Turned out to be a busted clip on the wiring to the TPS.
OP...I'd get your codes checked just to be sure. Maybe there IS a pending code.
Try manually putting your transmission down in 1st gear. If it takes off fine all the time doing that then your tranny isn't downshifting to 1st all the time. If it still does it then the coil pack issue would be my first guess.
@Ilyak, yea it does jerk alittle but i thought that would be normal.....
So even i have changed out my coil pack last year its possible it may need another set?
Ill try to get to a autozone to see if they can pull some codes for me. Cause its annoying. And i want my on tap power back!
@bhunter, i dnt get what youre saying do???
Thanks everybody for the speedy response!
litch
123
01-04-2024 07:01 PM
04-16-2020 05:15 AM
magiconthetire
10-26-2015 09:03 PM
maxima297
09-30-2015 03:32 PM
