Cam sensor leaking
Old Apr 3, 2010 | 01:11 PM
96nismomaxi's Avatar
.org window licker
Cam sensor leaking
hey its me i am having a problem with the max. The sensor that is on the Timing chain cover is leaking. Very badly! I would like to just reseal it if possible instead of replacing it. Does anyone know if that is possible. I will be attempting to seal it with black silicone, Gasket maker. let me know if this is a bad idea or an alternative way to repair it.
-Jared
Old Apr 3, 2010 | 02:23 PM
acercomp71's Avatar
Yes, it is very possible to replace the o-ring without purchasing a brand new sensor (that's wat I did and had no problems so far). Just find appropriate size ring and you are good to go. Well unless, sensor has an internal leak- start with new o-ring first, drive a bit, check if still leaks, in this case just buy a new sensor and get it over with. Easy on the bolt!
Old Apr 3, 2010 | 05:38 PM
hornepirate's Avatar
I use the nissan brand gasket sealer on mine....it was red in color... worked fine for me
Old Apr 4, 2010 | 10:07 PM
.org window licker
thanks guys
Mar 12, 2020 12:06 AM
gustavison
Oct 4, 2015 06:50 PM
RWCreative
Sep 21, 2015 11:01 AM
conansriver
Sep 11, 2015 10:26 AM
ag90fox
Sep 9, 2015 12:22 PM
