17x7 wheels?
17x7 wheels?
What are your opinions on 17x7 over 17x7.5 or 17x8 rims. The 17x7 are less expensive, but what about handling or the price of tires anyone with opinions or use 17x7 rims? I am thinking Konig Toxxins with a 42 offset.
C
C
Re: 17x7 wheels?
C
C
17 rims will only limit your tires sizes. I would go with at least the 17x7.5. That would give a larger selection of tire sizes. I have 17x8's and run 235-45/17. I have found that my tire size isn't as available as many of the others...
Ok,
Thanks for the advice, but I have already commited to purchasing the rims. They are 17x7 Konig Toxxins with a 42 offset (which I hear is ok for a Maxima, any thoughts?) I probably should use the search function, but what size tires should I look for. Right now I have stock 16 five spokes with Toyo FZ4 215/55/R16. I do not want to mess up the speedometer readings with something that is too low profile. Thanks for the help.
Charles
Charles
I have 17x7s and I'm running with 225/45/17s. Goto discounttiredirect.com and you get 17 choices in that size. Tirerack's search give 53 results in 225/45/17. Compared to the stock SE size of 215/55/16, 225/45/17 is 1.3% smaller.
DW
DW
I have 17x7 Konig Tantrum and they work find with my 235/45/17 Falken tires. No problem at all.
No problems here. I too run 235/45-17 on 17x7 rims.
I was told that you shouldn't go anywider than 225 on 17x7 rims. It can shorten the life of the sidewalls or something. The rims isn't wide enough to allow the belts to sit flat on the road. I'm not positive. There is a conversion meter in the links section off of the homepage. It will convert for you and tell you how far off your speedo will be. I had 225/60-15 and run 235/45-17 on 17x8 rims.
I have over 30K miles, including road racing and autoXing, on 17x7 wheels with 235-45 tires. Manufacturers recommend that 225 is the widest you go, but 235 will be just fine. They are just a little more difficult to mount.
Andy29
Sep 29, 2015 05:32 AM
