help with fuel level sender
Old Apr 13, 2010 | 10:32 PM
i30krab's Avatar
Question,
Should I install the rubber gasket under the sender cover with or without some fuel resistant sealer like Permatex 2B ?
Old Apr 13, 2010 | 11:09 PM
shadyonedeath's Avatar
wuts this thing look like?
Old Apr 14, 2010 | 03:02 AM
Trini Boom's Avatar
Originally Posted by i30krab
Question,
If you are talking about the o-ring that's on top of the tank when you remove the fuel sender unit, there shoul dbe no need to replace it. It is recommended and it does not cost much.
Old Apr 14, 2010 | 04:53 AM
cashoit's Avatar
If u can replace an o-ring then u might as well. They cheap and its jus due diligence to replace.
Old Apr 14, 2010 | 07:29 AM
i30krab's Avatar
Yes, I am referring to the rubber o-ring that's on top of the tank when you remove the fuel sender unit.
My question is do I use any type of lubrication or sealer on this ring, something like Permatex 2B to make sure the gas fumes can't leak through?
Old Apr 14, 2010 | 08:57 AM
ajm8127's Avatar
If Nissan suggests sealant in that location, it will be called out in the FSM. Did the one you removed have sealant on it?
Old Apr 14, 2010 | 07:11 PM
Trini Boom's Avatar
I do not recall using any sealant in that area. The o-ring should be enough to seal it properly. When you took it off, it should not have any sealant there.
jmlee44
Oct 2, 2022 02:13 PM
aw11power
Oct 10, 2021 04:57 AM
Forge277
Jun 13, 2016 09:26 PM
