OIL LEAK
Old Apr 17, 2010 | 08:32 PM
MaxxKid's Avatar
OIL LEAK
ok so I have this 97 max that is bleeding from somewhere on the lower right side of the engine. Did anyone have this problem?
Old Apr 17, 2010 | 09:55 PM
Trini Boom's Avatar
Sound like your upper oil pan u-shaped seal under your RMS (Rear Main Seal). Its a tedious task to repair if you don't have the tools.
Old Apr 18, 2010 | 01:08 PM
Snypa's Avatar
take some pictures if you can. Try to look up and see what spots are wet if any.
Old Apr 18, 2010 | 04:02 PM
MaxxKid's Avatar
ok i will get the car on a lift and get the pics
Old Apr 18, 2010 | 06:00 PM
wxm's Avatar
wxm
Check the oil pressure sending unit - a switch at back of lower oil pan. It is a common leaking problem.
Old Apr 18, 2010 | 07:10 PM
MaxxKid's Avatar
Old Apr 18, 2010 | 07:11 PM
MaxxKid's Avatar
there is a pic of under where it leaks
Old Apr 18, 2010 | 08:14 PM
HandsonMaxima.'s Avatar
looks to me like one of your orings behind your timing cover are going out. rear main seal would be closer to the tranny correct?
Old Apr 18, 2010 | 08:39 PM
MaxxKid's Avatar
so how much to fix. if its expensive the car is gone
Old Apr 18, 2010 | 09:18 PM
dan1el's Avatar
Yeah RMS is on the driver's side where the oil pan meets the tranny. But to be faie, OP said right side. The other guy probably thought he meant looking at the headlights.
Unfortunately it does look a lot the infamous rear timing case o rings leak. I've heard between $1200 and $2700 for the whole job. It's tedious and takes a lot of time. I think the first time I did it it took me and my bro in law 3 full days. Plus I got my timing off cause I was inexperienced and didn't turn the crank by hand before putting it back together. I killed 2 cylinders and ~$400 later I'm almost finished putting the car back together after getting a valve job done on the cylinder head. You should think of a few things:
-How much money do you make?
-How much free time do you have?
-How much do you know about cars (timing gear and stuff)?
-Do you have a friend willing to help? (there's several parts that really suck if you're on your own)
The parts for the job are dirt cheap. It's just a tube of RTV and a couple o rings, but there are some other things you should do while your in there or you'll hate yourself later (i.e. water pump, timing chain guide and tensioner, front oil seal, valve cover gaskets...).
I definitely don't advocate paying a mechanic when you can do it yourself. With this extensive of a job I personally wouldn't trust a mechanic to do everything right. At the same time if I knew a mech that I knew for sure would do it right I would probably pay like $600 maximum. Past that and it's better for me to do it my self.
Old Apr 18, 2010 | 09:21 PM
Trini Boom's Avatar
What's your definition of expensive? Can you do it yourself?
Old Apr 18, 2010 | 09:36 PM
this is the TT max guy right? im sure he has money.
quite honestly i would swap in a 3.0 and call it a day for 300. not worth the effort to change all that crap for a DD max that you would throw away at a moments notice
Old Apr 18, 2010 | 09:47 PM
dan1el's Avatar
Yeah that's the other option I forgot lol.
I don't have an engine hoist... just a 160 pc craftsman set otherwise I would probably have
-bought a $300 engine
-replaced the o rings while it was out of the car
-swapped it in
-fixed the other engine
-sold the old one for $300
Old Apr 18, 2010 | 10:10 PM
MaxxKid's Avatar
yes its me but this car is gone anyone want parts i an just going to donate the car that's it i am going to start taking my system out. any way my friend is doing the wiring on the other car so look for first stary up clip on saturday
Old Apr 19, 2010 | 06:14 AM
cashoit's Avatar
Im lookin at the pic the OP posted and that orientation is makin my head hurt.
Old Apr 19, 2010 | 03:26 PM
richard_85zxt's Avatar
Have you changed your oil weight around the time this started by any chance? sometimes engine tollerances aren't what they used to be and running say a 5W engine oil will leak while a 10W won't. I've changed to 5W and a leak appeared, changed back to 10W and it was gone. More of an issue with higher millage engines but a hell of a lot cheaper and easier than rear main.
Old Apr 20, 2010 | 03:12 PM
MaxxKid's Avatar
ok so i am going to change the gasket on the upper and lower oil pan cause there is no oil on the block just on the control arms and stuff, I went to o reille's and the guy told me to use 20w 30 or some heave oil cause the maxima uses heavy oil the car has 197 on it which oil to get
Old Apr 20, 2010 | 06:09 PM
Trini Boom's Avatar
Someone told me to swtich to 20w50 seeing that I have 298K but I choose to go Castril GTX High Mileage 10w40. I need to do the same but I am going to get thr RTV from the dealer and find someone with an engine hoist. Want to do it the proper way with tranny off.
Old Apr 21, 2010 | 07:20 PM
MaxxKid's Avatar
here is some pics of what i am dealing with
Old Apr 21, 2010 | 07:21 PM
MaxxKid's Avatar
MaxxKid's Avatar
something no one wants
Old Apr 21, 2010 | 08:06 PM
maxxx25's Avatar
looks like my leak on my max i changed the valve cover gaskets twice thinking that was it and its still leaking, i cant figure it out either atleast i know am not the only on sorry bro
Old Apr 21, 2010 | 08:22 PM
MaxxKid's Avatar
i have something in mind if it works i will let you know
Old Apr 22, 2010 | 09:10 AM
dan1el's Avatar
It seems unlikely that the oil pan gasket would get oil all over the cv shaft like in ur first picture, but hopefully that's all it is.
Old Apr 22, 2010 | 05:36 PM
i take my idea back, looks like your oil pump seal.
Old Apr 22, 2010 | 05:57 PM
Daniel1120's Avatar
You should take pictures a little higher on the motor, such as the valve cover gasket areas. Oil leaks should always be addressed with the highest leak taken care of first. You also desperately need a new belt.
Old Apr 22, 2010 | 06:22 PM
wardssix's Avatar
isn't that the oil switch?
Old Apr 22, 2010 | 06:26 PM
MaxxKid's Avatar
yea belts were done today
Old Apr 24, 2010 | 07:15 PM
Snypa's Avatar
could easily also be your power steering fluid. I just got done fixing RMS and valve covers...and i'm pretty sure it was done good, saw a small leak and the power steering hose is wet and pass axel is wet as well.
Old Apr 25, 2010 | 10:23 AM
Trini Boom's Avatar
Yeah you need to degrease your entire engine and monitor after wash to see where the leaks start. Also, you need to replace your belts. They are very brittle from those pics.
litch
123
Jan 4, 2024 07:01 PM
aw11power
Oct 10, 2021 04:57 AM
mclasser
22
Nov 12, 2020 01:58 PM
05RLS2
Apr 14, 2016 11:49 AM
