97 trunk on a 95 Gone Wrong..HELP
Old Apr 18, 2010 | 02:44 PM
19blackmax95's Avatar
So i have a 95 and i just swapped over a 97 trunklid. bolted on the trunk swapped the tails but i have one problem. The trunk won't pop open. from the keyless remote or the button on the inside. the trunk popper is functional . I changed the latch even and put my 95 latch on the 97 trunk. still nothing. Has anyone ever ran into this problem? im stuck now as i cant get into my trunk without going through the backseat
Old Apr 18, 2010 | 03:27 PM
95maxse3000's Avatar
try to get the trunk open and see if its lined up right. also try pulling up on the trunk as someone hits the button and see if it opens.
Old Apr 18, 2010 | 05:02 PM
JNCoRacer's Avatar
Just the tip.
The valet lock is activated it sounds like.
Old Apr 18, 2010 | 06:05 PM
AEMAXIMA01's Avatar
Next thing to check.
Can you open it with your key?
Old Apr 19, 2010 | 08:29 AM
dkillahster's Avatar
i wouldn't have ever thought about the key
Old Apr 19, 2010 | 08:32 AM
Xfactor22's Avatar
im having the same problem, the key is the only way for me to get in. There is a piece missing from my locking mechanism, i will let you know what it is to check if yours is missing.
Old Apr 19, 2010 | 08:46 AM
rdw72777's Avatar
If its the valet lock...
I don't think you can get in even with the key, so that will be the test.
If the valet lock is activated, I'm pretty sure only the original key will work. But let us know either way
I bought my Max used and clearly didn't have the original key (or for whatever reason, the key wouldn't open the trunk either). My brother was able to reach in with a ski pole and flick the little lock off. Finally it opened.
So what is the purpose of the valet lock anyways? Why would you want to require someone to use the key to open the trunk?
Old Apr 19, 2010 | 10:38 AM
because some of these idiots around here, (NOT THE ORG MEMBERS) dunno how to open our trunk with the button on our doors. in fact i had my car at a shop for an oil change. and i had the stuff in my trunk. and the guy calls me how do you open your trunk? the key i gave him doesn't open the trunk. so he calls me ask me how to open the trunk, and i had to tell a guy 4 times where the button is. He still never got it. so i had to walk downstairs, out the door, get in my GS, ride to the shop, (15 minutes away) go to my car and point with 1 hand and 2 toes where the trunk pop button was. But anyways.. some people aren't maxima inclined, so. anyways.
-enough of my rant-
Old Apr 19, 2010 | 12:14 PM
MaxiNone's Avatar
all 4th gens have this or just the SE and GLE models?...
Old Apr 19, 2010 | 12:22 PM
rdw72777's Avatar
-enough of my rant-
Now that's a funny story.
REDinLV
Aug 15, 2024 12:30 AM
mrgooch
Sep 21, 2015 08:43 PM
lux97Max
Sep 14, 2015 07:07 PM
Mikes14Max
Advance Paint and Body Work
Sep 14, 2015 05:28 PM
rbaker100
Sep 6, 2015 02:46 PM
