RPM drop when accelerating while low rpms.
Old May 2, 2010 | 03:40 PM
hito's Avatar
Hey guys, recently my car has been experiencing a rpm drop when my rpm is currently at roughly 600-700rpm area. For the most part, while i'm at a complete stop and have to accelerate again to get going.
The rpms drop to below 500 and and feels like it's about to stall then it gets moving with a surge.
Once the car is moving however, the problem seems to go away.
Now, it might be a coincidence, but this started to happen right about after when i turned on the A/C with the nice heat blast we got in NYC recently.
The problem still happens now with the A/C off...
This is on an 99' auto, had misfires on a cylinder before but that was due to bad ignition coils and that was changed out along with all spark plugs. This was maybe a year back now - but this rpm issue is new and never happened before.
Any ideas?
Old May 3, 2010 | 09:43 AM
[s3]'s Avatar
Have your alternator checked
Old May 3, 2010 | 10:17 AM
cashoit's Avatar
Any surging while driving? Codes?
I wd say perform the big three cleaning. MAF,IAcv, and TB. See if that helps
Old May 3, 2010 | 10:18 AM
cashoit's Avatar
And throw some chevron techron in the tank as well. see Sig
Old May 3, 2010 | 11:13 AM
njmaxseltd's Avatar
Clean the throttle body and IAC valve.
Old May 3, 2010 | 08:39 PM
hito's Avatar
Interesting, never heard of a alternator causing power loss before aside from dash lights coming up then sudden death. But will check it out and I guess the belts while I'm at it, maybe something is seizing and dragging it at the start?...
No surging and no codes. Will try cleaning the parts out this weekend, thanks.
Old May 3, 2010 | 11:04 PM
FallenOne's Avatar
check your belts as well... Also, check for a Misfire. AKA pull coils one at a time. Than PM me when you need a new one
Old May 4, 2010 | 06:18 AM
cashoit's Avatar
Fallen Advertisings Inc. lol
Old May 4, 2010 | 06:28 AM
angelmaxima's Avatar
this was the issue for me a few weeks ago when my rpm wasn't stale under 4000
Old May 4, 2010 | 07:06 AM
mike_98_max's Avatar
i have a similar problem. I own a 98 maxima 5spd MAF sensor has been changed but still chuggs sometimes when accelerating, annoying as hell! please help!
Old May 4, 2010 | 07:26 AM
cashoit's Avatar
Was it a new MAF? Spray some MAF cleaner on it. That dont help, inspect and test coils per FSM. Check plugs too
Old May 4, 2010 | 12:23 PM
FallenOne's Avatar
Clean MAF,Check/Change Plugs, CHange Oil, Check Coils, Clean your Air Filter, Change your Fuel Filter, Dont Hijack Threads.
Old May 8, 2010 | 07:23 PM
hito's Avatar
Okay, since my last reply, the car seems to be running fine again... BEFORE I even did anything...
However, my check engine light did come up - it was the O2 sensor indicating bank 2 sensor 2. Just went and changed it out, didn't want to chance my car stalling if that was the culprit.
Lets see what happens...
Mar 12, 2020 12:06 AM
jchronis2552
Sep 21, 2015 05:52 AM
Maxxx10
Sep 13, 2015 03:16 PM
jcvgn
Sep 10, 2015 08:03 PM
dcardello
Sep 3, 2015 11:44 PM
