When you do the water pump, what else should you replace?
Old May 3, 2010 | 04:21 AM
caseymaxima's Avatar
Hi Everyone,
The water pump has gone bad on my 96 Maxima with 130,000 miles. So with that in mind what other parts should I replace "while im in there"? I don't care much about pinching pennies, so if there are other parts that should be done now , I will do them. I have read that the timing chain tensioner can be an issue on 96's? Is the tensioner that Nissan sells an updated part? How about chain guides? Let the ideas flow......
Thanks,
Zack
Old May 3, 2010 | 06:36 AM
mryoungfresh's Avatar
When you do the water you dont have to replace anything else.. timing tensoiner can be replace easy if you feel like its bad or getting there,but the guide and all that **** u talking about is a complete timing job dog that job is not an easy job believe it or not and u only have a small amount of clearance to do this just do the water and leave the thing along man unless they bad which i douth...
Old May 3, 2010 | 08:50 AM
cashoit's Avatar
If u got the coin. I wd replace the chain tensioner. U have to remove it to get slack in the chain anyways. I say replace it. 96 tensioner is the older model prone to failure. Jus read the how-to, it will tell u what shd be replace.
DOnt worry about the chain guides.
Old May 3, 2010 | 09:03 AM
Thanks.....Is the tensioner that I would get from Nissan an updated part, thereby being better than the one currently on my 96?
Zack
Old May 3, 2010 | 10:23 AM
cashoit's Avatar
yup. from nissan.
Old May 3, 2010 | 07:07 PM
tattedmax69's Avatar
Yea i just replaced my WP yesterday pain in my a** lol, but i put in the new tensioner and she runs like a beaut. so i agree with everyone else on this
Old May 5, 2010 | 10:39 AM
dralucard's Avatar
if you're doing a water pump then also think about changing the coolant, belts, hoses and t-stat.
Old May 5, 2010 | 11:18 AM
showdown's Avatar
Because I Can
do tensioner...like everyone else said...your car will feel much better
Old May 22, 2010 | 01:57 PM
4G-riken's Avatar
i changed the pump but removed the engine from the car i changed motor mounts hard to reach sensores that lookt crusty the timing tensoiner ugly fuel lines vacum lines ...and this is just me but i regret not changing the oil pump because 2 wees later i had to change the oil pump 2
but for a normal water pump job change the tensoiner
Old May 22, 2010 | 08:43 PM
Fixer's Avatar
How long did it take to remove the engine?
Old May 28, 2010 | 12:25 AM
woog74's Avatar
So the timing chain tensioner is different/updated in later year 4th gens? Would a 98 have an updated tensioner in it already?
Old May 28, 2010 | 12:54 AM
whiteSE's Avatar
i belive its only on 95-96
Old May 29, 2010 | 02:27 PM
skypilots's Avatar
timing chain slack
im replacing my waterpump now. i am using a haynes book. they tell me to remove the slack I push in the tensioner and back off the crank 20 degrees. i did all this and I cant get the pump out. not enough slack to get over teeth
Old May 29, 2010 | 06:09 PM
Trini Boom's Avatar
Hold on a minute, did you just replace the tensioner without the updated guide? Is this an approved and safe method?
Old May 29, 2010 | 07:06 PM
skypilots's Avatar
done
Found the waterpump maintenance thread wow did that help. You take the tensioner right off. I love this org!
Old Jun 5, 2010 | 09:06 PM
Jarritos's Avatar
How do you know if the tensioner is bad?
Old Jun 7, 2010 | 04:59 AM
Well the problem for the 95's and 96's is that the tensioner that is available from Nissan is the updated part, that comes with one new chain guide as well. In order to replace the guide, the side cover of the engine must come off (according to the shop that did my car) and that adds major labor to the job. You can't use the new tensioner with an original guide, and you can't purchase an "old" style tensioner any longer. So on my car they cleaned up the original tensioner, and reused it. I returned the new tensioner and guide to Nissan.
Zack
Old Jun 7, 2010 | 05:00 AM
Usually a rattle sound at start-up from the pass side of the engine.
Zack
Old Jun 7, 2010 | 06:09 AM
cashoit's Avatar
Zack
That sucks. Timing chain guide work is wicked expensive. Prolly cheaper to replace engine.
00MAXI
Sep 2, 2015 10:23 AM
Alberto10mg
Aug 25, 2015 12:54 PM
acw
Aug 13, 2015 12:50 AM
Balkins
Aug 12, 2015 06:39 AM
acw
Aug 7, 2015 04:20 PM
