Clutch engagement problem
Old May 18, 2010 | 11:23 AM
f550maranello2's Avatar
I might have a thread on this i dont remember.. But, Im having a weird issue with the clutch in my maxima. Heres the lowdown.
5 speed swap.
Keyvalue clutch and pressure plate and tob
New master and slave and SS clutch line and new fluid
New clutch pedal
I do have the 17mm spacer for the master to firewall
Heres what happens..
Basically the clutch engagement position is real quick.. If the pedal travel is from 0 to 10 i can only get the clutch to engage (from on to full off) from like 2-4..
Now i have adjusted the pedal im multiple positions and all that does is move that point around.. so it will go to 6-8 or 7-9 and so on..
Basically its real hard to drive because the clutch engages way to quickly for the amount of pedal movement.. i have drive other maximas they are completely different.. the clutch is a lot more linear.. where mine is bell shaped..
I have bleed it multiple times so i know it not air.. what do you guys think.. im almost leaning to getting another clutch
Old May 18, 2010 | 11:40 AM
cashoit's Avatar
is that a stock clutch u bought? SOunds like clutch fork or somethin internal to tranny. Especially since u bed lines, new master and slave, adjusted pedal, and new lines. Sounds like the clutch or pp might be issue. 4 or 6 puck?
Old May 18, 2010 | 11:44 AM
this is a nissan "stock replacement" clutch and pressure plate.. the fork not new but its not bent or anything..
Old May 18, 2010 | 11:58 AM
cashoit's Avatar
let me see if i am fully understanding....u are saying the clutch engagement and disengagement is too quick. For instance, u dont have to push all the way to the floor to switch gears fluidly. Instead u can be off the floor, maybe an inch and the gear transitions are smooth with no tranny resistance??
Might jus be because its a brand new clutch. whenever i have replaced a clutch it has felt "extra engagey", if u will. Thats jus how a new one feels.
Old May 18, 2010 | 12:08 PM
no this thing has like 5k on it.. what it does it the point of engagement is like 1 inch.. the friction point isnt spread over the pedal range its concentrated at on point.. all i can do is move the point around but i cant increase it
Old May 18, 2010 | 01:10 PM
aackshun's Avatar
Still 5k... My exedy oem replacement didn't looses up till after a few track runs. and prolly around 8k miles.
Old May 19, 2010 | 10:03 AM
cashoit's Avatar
so engagement length is one inch? I see what u mean. Yeah my clutch doesnt do that at all. But my entire clutch system is 13 yrs old. I drove a new car and the clutch pedal felt the way u describe. Its disorienting but i guess u can get used to it. not exactly sure if a broken in clutch wd feel better?
Old May 19, 2010 | 10:36 AM
yea you got it.. it really sucks when i have people in the car since i have to slip the clutch more to get the car going..
sctludwig
Sep 1, 2022 01:32 PM
Mar 12, 2020 12:06 AM
boomerbrian
Oct 31, 2018 10:25 AM
BkGreen97
Apr 2, 2016 05:47 AM
pears
Sep 18, 2015 05:25 AM
