98 maxima no start/ no crank after lic plate light short
Old May 20, 2010 | 10:45 PM
garyrr's Avatar
SO today while replacing my licence plate bulbs the power and ground touched and i heard a loud click from the front end of the car. The running lights and side markers dont work but the signals and brake lights do. I have cheked all the fuses and they seem fine minus "tail L" had no power going to it(fuse is not blown). After this i tried to crank and nothing happened. PLz does anyone know which relay/ wire i have effed up
Old May 21, 2010 | 12:28 AM
EsQueue's Avatar
Actually, you have some large fuses under the hood. I'm nearly 100% sure that it is one of those.
If you can't find them, pm me and I'll check through my fsm.
Old May 21, 2010 | 04:15 AM
bob-lee's Avatar
look on the fuse boxes for the ones that say front lights and front sidemarkers inspect them and you might find the culprit's
Old May 21, 2010 | 07:06 AM
ajm8127's Avatar
That's very strange that it won't crank. The starting system is protected by h, 33, and 13. Try one of those. Did you check for power at Tail\L with the head lamp switch one or off? That fuse is only powered with the parking lamps are turned on (first setting for the switch).
Old May 21, 2010 | 07:21 AM
Nopike's Avatar
Fuse # 66 (15Amp) in underhood fusebox is probably blown. Should not keep the car from starting though.
Does you horn work? If not check the fusible link 140 Amps it's located in the middle of the under hood fuse box. Neither of these should keep the car from cranking.
Check the 30Amp fusible links in that box also, one of those would prevent cranking.
Old May 21, 2010 | 07:49 AM
[s3]'s Avatar
The license lights won't blow the fusible links. You gotta do some major damage to blow those fuses like charging your battery backwards etc.
Old May 21, 2010 | 10:31 AM
ajm8127's Avatar
Nopike,
I thought about that fusible link also. I couldn't connect the dots to the starting system though. On a second look, the anti-theft system is the missing link. However, it looks like that relay is NC (EL-30), so if no current was flowing through the coil of the relay, it would still conduct and allow the clutch interlock relay coil to be powered.
I can't see why shorting the license plate lights would take out the starting system, but not the five amp fuse that protects those lamps. This is interesting. I have to admit, I'm excited for a resolution.
OP, next time when doing electrical work, make sure the power is off first. Really, you should disconnect the battery too.
Old May 21, 2010 | 11:31 AM
Nopike's Avatar
Originally Posted by ajm8127
Nopike,
I used to get more involved with the electronic issues on this forum. Now I generally just take a quick look at the drawings and provide possible causes. I have not really looked at the circuits as thoroughly you have.
1) The problem should be a blown fuse. 2) It is unlikely but possible that the starting issue is unrelated to the plate light short.
If you enjoy electronic trouble shooting these things can be fun.
The op should find out if anything else is not working, windows, power seats, Fog lights. That may help point to the trouble.
Old May 21, 2010 | 03:47 PM
garyrr's Avatar
Problem fixed
Today i came into work an hour early to chek things out and all the lights worked fine, It still did not start tho. I removed my neg terminal n main fuse and let it sit to reset the ecu. After all that it started fine. Im guessing i blew a curcuit breaker that reset sometime between the short and me coming to work.
Old May 21, 2010 | 04:48 PM
Nopike's Avatar
Problem fixed
Or maybe a bad connection at the battery? Might want to make sure terminals are clean.
Old May 21, 2010 | 07:26 PM
EsQueue's Avatar
Problem fixed
No circuit breaker that is reset by time that I am aware of on the maxima. As the poster said above, maybe a bad connection.
Good that you got it working though.
Old May 22, 2010 | 03:44 AM
ajm8127's Avatar
I second that.
kjlouis
Nov 24, 2018 06:09 AM
Dennis Twohy
Oct 1, 2015 06:01 PM
spidgeon
Aug 18, 2015 05:46 AM
Tanvirkamal
Aug 5, 2015 01:32 AM
yat70458
Aug 3, 2015 01:16 PM
