Problem after starting
Old Dec 11, 2001 | 03:35 PM
WaarrEagle's Avatar
RPM's drop after starting
Up until this morning I wasn't sure if what I am about to describe was normal, now I know its not. I turn the key and the car starts fine every time. The RPM's jump to 1k or so for a second and then they should settle down to around 800 right??? Well, for a while mine have been dropping to 400, then recovering. Then it got worse and they were going to 200 and almost dying but this morning it did die. Then I started it back up and once it gets going its smooth as can be. The engine runs perfectly. Whats wrong?? I have an intake and y pipe. Thanks.
Old Dec 12, 2001 | 03:32 AM
iamit's Avatar
Re: RPM's drop after starting
Mine did that too. You can take it in, and they fixed it in just a short time. The sheet said "Base idle correction"... Good luck!
Old Dec 12, 2001 | 04:53 AM
MAXEJA's Avatar
whenever i turn all my lights on the rpms dip and it feels like my car will stall. I believe what you have to do is increase your idle. what iamit said is correct.
Old Dec 12, 2001 | 05:06 AM
WaarrEagle's Avatar
Re: Re: RPM's drop after starting
I figued that out last night by pure luck. I haven't started it cold since then but I will find out in about 30 min. The base idle on mine was 400 when it should have been 700. Hopefully I fixed it. Thanks.
Old Dec 12, 2001 | 05:24 AM
BRIGBOY's Avatar
The car should rough idle at near 1100 rpms
until you take it out of park, then they will drop to normal the 700.
Old Dec 12, 2001 | 07:07 AM
BRIGBOY's Avatar
My car was actually rough idling at 1300 this morning.
I think different cars will idle slightly differently depending on needs like mileage etc.
I know mine was adjusted professionally no more than a month ago.
Old Dec 12, 2001 | 11:46 AM
98sterlingmist's Avatar
Found this on a search and have this problem
Sorry to bring up this old thread, but I found it in a search. I am having this problem every other day. The car will sit for a while. When I start it up, the engine cranks right up and then the RPM drops to 400 and then the car dies. It will die 2 or 3 times until finally I have to give it a little gas to get it going. After that it start fine. This has been going on for about a week. The car starts, but wants to stall.
Someone told me It may be water in the gas, but I am getting good gas mileage and no power loss. My starter is new (4months old), but the engine starts, just stalls out like it is not getting enough gas or air. Any thoughts?
Old Dec 12, 2001 | 12:46 PM
BRIGBOY's Avatar
This thread is from today.
Get your rough idle adjusted.
Old Dec 12, 2001 | 06:10 PM
WaarrEagle's Avatar
Re: Found this on a search and have this problem
This is not an old thread. I posted it last night and fixed my problem. Warm up your engine, turn it off, and unplug the TPS sensor. Turn the car back on, rev it to 2k-3k twice and let it sit for a minute. Check the idle. It should be 700. (Mine was 400 at this step and died during the process) If its not adjust the screw until it is. Then plug the TPS back in and your problem should be fixed!! You are experiencing the EXACT same thing I was and this fixed mine. Good luck!
Old Dec 12, 2001 | 07:38 PM
bluman3's Avatar
Re: Re: Found this on a search and have this problem
i am having the same problem on my 95 maxima.what is and where is the TPS sensor? also where is the screw that adjust it located?
thanks, tim
Old Dec 12, 2001 | 08:30 PM
WaarrEagle's Avatar
Re: Re: Re: Found this on a search and have this problem
thanks, tim
The TPS sensor is the brown connector in the attached picture. The adjustment screw is back behind it. I believe its to the left a little. It faces straight up. Having a Chiltons manual while doing this was very helpful.
Old Dec 12, 2001 | 08:52 PM
WaarrEagle's Avatar
the attachment...
sctludwig
Sep 1, 2022 01:32 PM
mvm062
Nov 30, 2020 09:00 AM
cruce91
Sep 20, 2015 10:23 AM
trungg86
Sep 4, 2015 04:58 AM
dcardello
Sep 3, 2015 11:44 PM
