False Oil Reading???
Old May 30, 2010 | 09:24 AM
Dondon321's Avatar
a while ago i changed my oil w/ synthetic penzoil. and it showed that the oil was the right amount. But today when i checked it, it said it has double the oil???? Can anyone help with this?
Old May 30, 2010 | 09:28 AM
98nismomax's Avatar
did you check it after you drove it?
Old May 30, 2010 | 09:31 AM
Dave H.'s Avatar
Our car's dipsticks are hard to read when doing an oil change or when the engine is warmed up. The oil has to drain back down to the pan to get an accurate reading. It's best to check it when cold, like first thing in the morning.
How much oil did you put in? I believe it's around 4.25 quarts...someone else will confirm I'm sure.
Old May 30, 2010 | 10:02 AM
EsQueue's Avatar
Cold on a level ground. Kinda picky
Old May 30, 2010 | 10:19 AM
2000_MAXIMA_KING's Avatar
if u drained all the old oil out and put around 4.25 to 4.5 quarts then ur ok theres no way u have double unless u checked ur oil with the engine running or something then it'll soak the dipstick and give u the wrong reading
Old May 30, 2010 | 07:56 PM
Dondon321's Avatar
ohh yeahhh ur rightt. lol i checked it with the engine running. thanks alot guys!
Old May 30, 2010 | 08:10 PM
FallenOne's Avatar
The VQ Dipstick is a Tricky Thing.
Old May 30, 2010 | 10:11 PM
mahanddeem's Avatar
+1 on checking the oil level in the next morning after the oil change day(before you turn the car on)...would be the most accurate
220k+ A32
18
Sep 22, 2015 11:39 AM
JoshG
51
Sep 21, 2015 10:41 PM
f.matejaiii
Sep 21, 2015 12:09 PM
ag90fox
Sep 9, 2015 12:22 PM
sdotcarter
Sep 2, 2015 09:53 PM
