Will a 1995 obd2 maxima motor swap fine into a 1998 obd2 maxima?
Old Jun 7, 2010 | 05:23 PM
speedofsalt32's Avatar
I got a rusted '95 and a blown '98 will i have any problems ?
Old Jun 7, 2010 | 05:35 PM
f550maranello2's Avatar
the motor will but not all the electrical.. just swap the stuff you do/dont need
Old Jun 8, 2010 | 07:31 AM
cashoit's Avatar
call the dealer and ask them. THe nissan dealer in my area is wicked helpful when i have maxi questions. SEARCH the org my friend. Im not certain about the answer and i dont wanna steer u wrong.
Old Jun 9, 2010 | 02:26 PM
f550, do you know how much of the electrical ill be different?
Old Jul 13, 2010 | 07:42 PM
hils0301's Avatar
alot of it should be the same i just swaped a 97' into my 95' and only found 1 different electrical plugin. something on the top of the intake manifold that i think has to do with the fuel? i also swaped ecu's
Old Jul 14, 2010 | 09:37 AM
Just so everyone knows. I ended up switching over the upper intake manifold. It had a vacuum line coming out of the top the 1995 did not. and it had all the evap stuff on the 1998 manifold anyway. I switched over the egr vacuum lines and such, the egr system in itself was the same. the catalytic converters are a diffrent shape, the 1995's just look way nicer. I kept them I dont know if it'll throw codes yet or not. The throttle body had a different tps in it. two plugs on the '98 one on the '95 the 1998 has a better looking injection system in that the got rid of the fuel mountain climb in the loop side of the fuel rail, however the rails themselves are the same. I used to 1995 fuel rails because the 1998 had damage from the other engine blowing up, the engine is in an wired im still waiting on a clutch to re-install the trans.
Finkle
Sep 27, 2015 09:53 PM
laparka66
Aug 6, 2015 09:36 AM
julian888
Aug 6, 2015 04:39 AM
julian888
Aug 5, 2015 08:26 PM
kjm900r
Aug 5, 2015 07:14 AM
