Replacing valve cover gaskets
Old Jun 9, 2010 | 06:07 PM
Paintguy84's Avatar
I am going to be replacing my vc gaskets soon, can somebody give me a list of everything else I need, like intake gaskets and what not,thanks.
Old Jun 9, 2010 | 07:02 PM
HandsonMaxima.'s Avatar
10 or 12MM socket. a screw diver for the rear VC, a 8MM for the front. you'll also need a allen wrench to get the engine cover off.
your going to need a new TBgasket because the stock one is paper type.
if your going the rear you might as well buy a knock sensor and just take the LIM off and install that while you have everything else off and out of the way
Old Jun 9, 2010 | 07:55 PM
DennisMik's Avatar
If you are going to do the rear cover gasket, you will need to take off the UIM (upper intake manifold). Org member ATTappman did a nice thread with pictures on 7-26-2009 titled "Removing Upper Intake Manifold (UIM) w/pics".
found the link:
http://forums.maxima.org/4th-generat...im-w-pics.html
Old Jun 10, 2010 | 11:58 AM
schmellyfart's Avatar
Make sure you keep track of those little "hats" that go around the bolts in the valve cover.
Old Jun 10, 2010 | 06:01 PM
Sproket13's Avatar
i'm fixing to do this to my newly aquired 96. Saw a good write up, i feel fairly confident! Best of luck to you
Matt93SE
Apr 8, 2018 09:23 AM
raffivegas
Aug 23, 2015 09:54 PM
MaximaDrvr
Aug 19, 2015 08:20 PM
Nintensity
Aug 13, 2015 05:41 PM
