vq35 heads on vq30 short block??????
Old Jun 19, 2010 | 02:59 PM
ronvr6's Avatar
hey i allready did my vq35 swap like 2 years ago till las night when i lost my engine cause the rain by the intake.
i still have my vq30 jdm in good conditions and i was thinkin on putting my vq35 heads on the vq30 short block. do u thinnnnk its a good idea??????????
vq35 swap katback, intake. i push 13.8 @99mph 1/4mille, with 220whp.
Old Jun 19, 2010 | 03:41 PM
NmexMAX's Avatar
dot dot dot ...
http://forums.maxima.org/all-motor/6...ads-3-0-a.html
Old Jun 20, 2010 | 02:01 PM
NJ3ndri's Avatar
yea id like to find out about this too. my friend keeps telling me you can do it but 1 person isnt going to convince me lol
Old Jun 20, 2010 | 03:51 PM
modenaf1's Avatar
Not worth it. If I recall correctly, but don't quote me on it:
1.) VQ35 combustion chambers don't match the bore of the VQ30 block
2.) VQ35 combustion chambers are more prone to detonation than VQ30 chambers, not to mention with them not matching the bore it makes this problem worse.
3.) VQ35 heads on the VQ30 lowers the compression ratio which means you will make far less power NA with 3.5 heads on a 3.0 than with 3.0 heads on a 3.0. Even boosted it isn't worth it because of the above listed detonation and mismatch issues, and the fact that while boosting you can make enough power on 3.0 heads to break just about everything on the car before you run into head flow limitations.
Old Jun 20, 2010 | 04:32 PM
NmexMAX's Avatar
dot dot dot ...
Why are VQ35 heads prone to detonation? If anything they'd be less prone due to their larger cooling jackets.
Old Jun 21, 2010 | 06:20 PM
RedfoxXx's Avatar
Back in the early days of the vq35 swap they did that backwards (vq35 short block with vq30 Heads) and that worked out well
I would just rebuild your existing vq35
Old Jun 21, 2010 | 11:03 PM
maxgtr2000's Avatar
KH3 by popular demand
Old Jun 22, 2010 | 12:05 AM
whiteSE's Avatar
+2
Old Jun 22, 2010 | 05:03 PM
modenaf1's Avatar
Whoops, I did some searching, I must have read that backwards. The VQ35 heads are BETTER at knock suppression.
jmlee44
Oct 2, 2022 02:13 PM
mclasser
22
Nov 12, 2020 01:58 PM
howardis
Dec 11, 2019 06:10 PM
jaydot901
Sep 29, 2015 01:18 PM
