P0400 EGR Tube Question
Old Jun 26, 2010 | 06:47 AM
Ciucca's Avatar
I've read all the threads concerning P0400 being a clogged EGR tube, and that it needs to be cleaned. I am getting this code intermittently, that is after clearing it comes back after 1 to 2 weeks. Could this mean that only the temperature sensor needs to be cleaned, since it is working most of the time? I've noticed some rust in my crossover pipe, could an exhaust leak be the issue also? I've reved the engine to pretty high RPM in idle and drive without seeing the light. So again it seems to me that it is probably not a blocked EGR tube, since the code should return pretty quickly, or right away after clearing.
Does anyone have any comments or thoughts?
Old Jun 26, 2010 | 12:43 PM
mateusz1945's Avatar
p0400 p1400
let me join your problem
i got 98 SE throwing p0400 and p1400 few days later. I've read somewhere :
Originally Posted by dr-rjp
4th UPDATE:
I spoke to the local Infiniti Serive Manager who began working on I30's beginning in 1998 (my model year).
He said that, in 1999, a 14-page bulletin was issued by Infiniti for all 98-99 I30's about breaks in the EGI harness that can trigger all sorts of CEL's, beginning with P1105, P0400/P1400, and about every other drivability issue you can name (which is also why we have a diverse set of solutions offered here - including taking it to Infiniti service and let them figure it out).
it could be solution, can somebody tell me more about this EGI harness?
could it be one that on the right side of intake manifold ( that bother you when you replace knock sensor? i could brake it... thx
Old Jun 26, 2010 | 04:58 PM
jholley's Avatar
Here's that bulletin regarding the harness bend:
http://www.lyberty.com/car/Maxima_A3...NTB98-008b.pdf
Old Jun 26, 2010 | 08:20 PM
EsQueue's Avatar
I used to get 2 codes of which I can't remember but both were egr. One, I would get after a week or so of driving but didn't affect the car. The other, I probably got 3 times in 7 months span and would cause the car to go into limp mode (can't rev past 3k rpm). I disasembeled the egr solenoid and cleaned it. I took a wire coat hanger and push it down the egr tube and twisted away. I also sprayed some carburetor cleaner in the tube. Have been egr code free since.
Old Jun 27, 2010 | 06:21 AM
Ciucca's Avatar
So you removed the sensor and from the egr tube and cleaned that? Did you spray the carb cleaner in the tube while it was on the car?
Thanks.
Old Jun 27, 2010 | 11:54 AM
EsQueue's Avatar
Thanks.
I pulled off the mechanical solenoid, dissasembled and cleaned it. I then tested it with 12v to confirm that it worked. I acutally jumped pins till I saw movement.
I then unbolted the egr tube fron the intake manifold and while it was still connected to the exhaust I ran a wire coat hanger down it. I also sprayed some carb cleaner while it was still connected using a tube.
shilov
Feb 19, 2024 09:40 PM
bumpypickle
Sep 20, 2015 08:22 AM
bumpypickle
Sep 19, 2015 01:07 AM
pears
Sep 18, 2015 05:25 AM
DarjeelingRose
Sep 15, 2015 01:20 AM
