Gas Petal Tension
Old Dec 12, 2001 | 07:09 PM
maxperformance's Avatar
Gas Petal Tension
I have my hooked up max, its a 1995 GLE, and when i push the gas in not too hard in any matter. Its very simple to do, its very loose and take no effort to push it. I drove a 2000 Maxima GXE and the tension on the gas petal is very tight and ya kinda havedto "push it down". Is there anyway i can change the spring in the throddle. I popped the hood and there seems to be a large circular spring, is it look. How do i tighten the gas peddle tension.
Maxperformance
Old Dec 12, 2001 | 07:25 PM
mzmtg's Avatar
Minister of Silly Walks
Re: Gas Petal Tension
Maxperformance
You can adjust the tension in the t-h-r-o-t-t-l-e cable under the hood. This will make your gas p-e-d-a-l tighter a little.
Old Dec 12, 2001 | 07:39 PM
ny96max's Avatar
or you can experement and pull out the enitre gas pedal assembly and buy a new tension spring. i think they run like $50, that will make the car feel like new!
ill do that one of these days
Old Dec 13, 2001 | 10:31 AM
araffio's Avatar
Maxperformance
I have the same complaint! My 98 SE's gas pedal is loose as hell. My mother had a 98 SE that she just turned it, the gas pedal on hers was tight and felt much better than mine. I tried tightening the thrttle cables under the hood, but all that did was increase my idle RPMs, didnt change tyhe gas pedal, so I put them back to how they were. I took a look under there and saw a large spring that is obviously our problem, the pedal rocks on that and it provides the tension. I didnt look into getting a new one because it seemed like it'd be a bi*** to replace. Ill live with it until an easier solution comes along.
Old Dec 13, 2001 | 12:10 PM
Re: Re: Gas Petal Tension
I heat ya i dont know what to do, but look under the steering column and there is another screw in which the petal pivots on. That doesnt look like a ***** to repair, its just finding it Heres a pic.
Old Dec 13, 2001 | 12:13 PM
mclasser
22
Nov 12, 2020 01:58 PM
maxinout93
Oct 31, 2015 02:04 AM
ef9
Oct 4, 2015 08:43 AM
