Windows
Old Dec 12, 2001 | 08:19 PM
MastaShimz's Avatar
Windows
When i have all four windows down in the car....and i bring them all up at the same time.....I get this little click sound....and the windows stop going up for a while...n then i hear another click..n the windows start to go up again........NE1 know y????
Old Dec 12, 2001 | 09:40 PM
98BlaximaSE's Avatar
I know what you're talking about. If you have to door open, you see the door lights go out as well. I'm assuming it has something to do with the power usage at once. Don't really have any clue why.
Old Dec 12, 2001 | 11:43 PM
minmax's Avatar
that happens to me sometimes too, except, it's with my sunroof window... it'll stop closing, and then start closing again in a bit, when i'm trying to close all the windows at once.
Old Dec 13, 2001 | 04:37 AM
Zack_Rad's Avatar
overload
Sounds like there is an overload built into the circuit. It's just an element that opens the circuit when it gets hot and shuts when it cools off. You should be able to use all of you windows at once (I can). You probably have a motor or two with a low resistance, when combined with the rest the current overheats the circuit a bit.
I'm just guessing at this.
-Zack Rad
Old Dec 13, 2001 | 10:32 AM
TILLEYS99's Avatar
Lives in a 11sec maxima
Its called a circuit breaker when you put to much of a load on it it will trip the breaker, dont worry it will not hurt anything.
Old Dec 13, 2001 | 01:09 PM
Zack_Rad's Avatar
circuit breaker
Conventionally a circuit breaker doesn't reshut on its own. Normally requires manual intervention. An overload on a motor circuit does reshut. All thats neither here nor there, the idea is similar enough.
-Zack Rad
Old Dec 13, 2001 | 10:39 PM
TILLEYS99's Avatar
Re: circuit breaker
-Zack Rad
you might want to look into that before you comment because the y do have breakers that do reset themselves.
Old Dec 14, 2001 | 09:47 AM
Craig K. Balgobin's Avatar
it might b the window regulators
Old Dec 14, 2001 | 10:12 AM
iansw's Avatar
I do know if you do it too much, you can initiate a warp-core breach in the starboard nacell.
Then you need at least a Tachyon Beam Generator to contain the Anti-matter explosion to keep the breach from reaching the rest of your Max.
Old Dec 14, 2001 | 10:20 AM
98MAXNY's Avatar
This is normal both my maxima and pathfinder do it
Old Dec 14, 2001 | 10:28 AM
njmaxseltd's Avatar
Took the words right out of my mouth.
Old Dec 14, 2001 | 10:30 AM
98MAXNY's Avatar
REDinLV
Aug 15, 2024 12:30 AM
Fbana41
Aug 29, 2016 12:18 PM
lrb6805
Sep 24, 2015 05:03 PM
