my car is bugging the piss out of me
Old Jul 11, 2010 | 03:12 PM
tigersharkdude's Avatar
my car is bugging the **** out of me
So I think I have a coilpack going bad. Occasionally at idle my car "misses" but when I give it gas it stops, but if I give it a lot of gas (like going up a hill, and needing to down shift) it "bucks". Last few times (3) its been a coil, but my CEL wont come on, and the people that work at AZ wont check it if its not on. Any ideas, besides the manual checking of codes ( I dont want to do this, because I dont want to break the plastic screw)
Old Jul 11, 2010 | 03:16 PM
maxfever1987's Avatar
pull out the connector for eachc oild one by one, see a diff then that coil is good, dont see a diff then thats your problem, also last time you changed plugs? and if its not the coils might be injectors and since your a 99 this problem is a HIGHLY common issue for your car's year
Old Jul 11, 2010 | 03:23 PM
plugs were changed about 2 years ago, I checked them about 4 months ago and they looked fine. I would pull individual coils but the problem is intermittent so IDK if that would work. I hope to buy the other 3 coils soon, and be done with this ish
EDIT: HIGHLY common and super annoying
Old Jul 11, 2010 | 03:43 PM
SiathLinux's Avatar
This could also be the early signs of a catalytic converter clogging - just my 2 cents.
Old Jul 11, 2010 | 03:44 PM
my car needs to throw a CEL. I dont think Ive ever wished for a CEL
Old Jul 11, 2010 | 03:50 PM
Remminator's Avatar
You could go to autozone and borrow their code reader. Plugs in under dash on passenger side. Are you sure it's a coil pack? I had a problem with a car similar to yours and it turned out to be a hole in the air inlet. Unlikely, but worth a try.
Old Jul 11, 2010 | 03:52 PM
I have checked all of the intake and found nothing. Day by day the problem is getting worse (as always when it does this), I say within 5 days the CEL will come on.
Old Jul 11, 2010 | 04:07 PM
KilJim's Avatar
Advance Auto will just give you the reader for you to take it out and check yourself
Or maybe just unplug an O2 sensor to force the CEL on....lol
Old Jul 11, 2010 | 04:41 PM
not around here, they will not let you rent the code reader at any of the parts stores around town
Old Jul 11, 2010 | 05:04 PM
Trini Boom's Avatar
Which coils do you have? The Mitsubishi or Hanshins?
Old Jul 11, 2010 | 05:23 PM
IDK
MikesChevelle
Nov 23, 2024 11:17 AM
Lakersallday24
Jun 16, 2019 01:35 AM
kjlouis
Nov 24, 2018 06:09 AM
Balkins
Aug 12, 2015 06:39 AM
MikesChevelle
Aug 9, 2015 11:50 AM
