Tune up help
Old Jul 14, 2010 | 01:26 PM
Black96Max's Avatar
Tune up help
Just bought a 97 5 speed maxima from a friend of mine...has 180K on it but is running great and has been well maintained since he bought it with 60K on it...this is going to be my daily driver and my new 370z will be the weekend car...i just need some advice on what i should have checked out and what services should have been done or need to be done....thanks again for all your help
Old Jul 15, 2010 | 12:55 PM
soto2635's Avatar
plugs and the coils, radiator fluid , brake fluid, p/s fluid and of coarse ur oil and belts u should be good to go
Old Jul 17, 2010 | 06:30 AM
Matt93SE's Avatar
STFU n00b!
Posting in the right forum would be a good start.
Old Jul 19, 2010 | 07:35 AM
Bobo's Avatar
All of the following should be checked, but not necessarily replaced. Also check transaxle gear oil and replace with only GL4 (NOT GL5 or GL4/5). Check PCV valve. Check cv boots, exhaust, suspension.
The coils are probably fine. If it ain't broke, don't fix it.[
QUOTE=soto2635;7645270]plugs and the coils, radiator fluid , brake fluid, p/s fluid and of coarse ur oil and belts u should be good to go[/QUOTE]
Old Jul 20, 2010 | 01:26 PM
creammotors's Avatar
Chek the air filter, fuel filter, and all fluids & belts. I would check the spark plugs as mentioned by someone else.
Old Jul 20, 2010 | 03:54 PM
Kevlo911's Avatar
Kevlo for President
There is a 60k tune up link in the maintenance and mechanical thread in the stickies. Check it out
litch
123
Jan 4, 2024 07:01 PM
aw11power
Oct 10, 2021 04:57 AM
Socalstillen
Sep 26, 2015 12:01 PM
zzznightmarezz
Sep 21, 2015 06:32 PM
Maxboy23
Sep 4, 2015 06:04 PM
