Engine not well... Help!!
Old 07-20-2010, 06:56 AM
  #41
cashoit's Avatar
jus run new wire from the relay contact to the MAF.
cashoit is offline
Old 07-20-2010, 11:52 AM
  #42
Trini Boom's Avatar
+1. Just get some wire and run a temporary connection from the relay to the MAF. Doesn't have to be neat....if you don't have wire, you can get some for a few bucks.
Trini Boom is offline
Old 07-20-2010, 02:00 PM
  #43
arrrghhh's Avatar
Originally Posted by jholley
Do as I said in an earlier post and check for continuity between pin 5 of the EGI relay to the MAF red wire. If you don't get continuity then you'll have to troubleshoot the wiring from the relay to the MAF. If you do get contiuity then it's the ECM that needs to be troubleshooted.
Sounds good. I heard it was an issue with analog voltmeters and I shouldn't use 'em on sensitive circuitry - I can't seem to find my nice digital multimeter, so I'm not going to do the continuity test...
I'll definitely try some temp wiring from the relay box to the plug in the harness tonight. Thanks again guys!
arrrghhh is offline
Old 07-24-2010, 07:25 PM
  #44
arrrghhh's Avatar
Took it to a shop, it was a bad wire going to the plug for the MAF. $48, not bad! I think the guy felt bad because he said that it was a bad MAF at first, but I pressed the issue that it had basically been through 3 MAF's....
So yea, car is good to go now! Thanks for the help guys.
arrrghhh is offline
Old 07-24-2010, 08:56 PM
  #45
99zx2's Avatar
ouch. for $48 you could've gotten a soldering iron kit and a manual on how to use it, some wires, and some left-over cash for a six-pack oh, and a priceless experience of doing it all yourself!
99zx2 is offline
Old 07-25-2010, 06:16 AM
  #46
jholley's Avatar
It must of been the power wire I suggested you check for continuity. With the IGN on you got no voltage at the MAF plug but you did get voltage at the EGI relay that feeds the MAF sensor.
jholley is offline
Old 07-25-2010, 09:04 AM
  #47
arrrghhh's Avatar
Yea, I also don't have a good multimeter... I have a crappy analog one, which I was told was not a good idea to check continuity with an ECM. Some digital ones aren't that great either...
I'm not comfortable ripping apart the harness myself. Maybe you are 99zx2, but I am not. I could've diagnosed the crap outta the problem but not been able to actually fix it. I appreciate the help I received in this thread, it definitely gave me some great ammunition when I actually did take it in. It was also nice of my buddy to let me borrow his ODB-II
arrrghhh is offline
James92SE
142
01-02-2024 09:23 AM
msellas
09-23-2015 09:16 PM
Socalstillen
09-20-2015 11:46 PM
mikeymouse1995
09-18-2015 06:42 AM
seesole
09-14-2015 12:38 PM
Quick Reply: Engine not well... Help!!
