MEVI Activation Issue
Old Jul 19, 2010 | 10:14 AM
midnight0045's Avatar
I'm having the toughest time getting my MEVI to activate properly.. here is my problem
The suction from the Fuel line passes through the vacuum canister, then to my EGRC Solenoid switch and on to my actuator.
The problem I'm having is that when I start the car and all my hoses are linked.. suction is immediately led to my MEVI actuator arm pulling it back instantly just on start up... and the funny thing is when my engine hits 5300 the actuator closes.... then re OPENS again as the car falls back towards idle... so.. the SWITCH MOTION is working great!
though...My MEVI vacuum line is working backwards... It should be shut on startup and it should pull back when it hits 5300RPM.. what is my issue here? A vacuum line ran wrong? I just swapped my EGRC switch so i don't believe that is the issue..
Old Jul 20, 2010 | 10:40 AM
can anyone with a MEVI help me here? Explain to me exactly how you have your vacuum lines ran? I have seen writeups and diagrams but it would help to get someones personal use
Old Jul 20, 2010 | 10:56 AM
cartman854's Avatar
What is ur activation switch? Most have a point where they activate and then deactivate at a lower rpm.
Old Jul 20, 2010 | 01:30 PM
summit. it activates at 5300 but my vacuum lines are what is the problem here
Old Jul 20, 2010 | 01:31 PM
Leo_Koneval's Avatar
Yeah there was a member here at a WA meet with a MEVI and he said he needed a RPM switch to make it work properly but he couldn't find one.
EDIT: Whoops never mind haha I see you already have a switch
If you want try messaging Blackwind he has a MEVI and I think everything is hooked up just right except for the missing switch.
Old Jul 20, 2010 | 05:13 PM
cartman854's Avatar
Ill be installing my MEVI in 3 weeks or so, so if this is still unresolved by then I would be able to help then.
Old Jul 20, 2010 | 09:42 PM
If you follow this wiring/vacuum diagram, you'll have no issues.
Mar 12, 2020 12:06 AM
BkGreen97
Apr 2, 2016 05:47 AM
BrandonCause
Sep 14, 2015 10:41 PM
Mikes14Max
Advance Paint and Body Work
Sep 14, 2015 05:28 PM
NissanNismoZ
Sep 12, 2015 07:30 AM
