Bose volume knob troubleshooting
Old Sep 14, 2011 | 04:30 PM
  #41
Caticorn's Avatar
Originally Posted by Nopike
FWIW The Bose and most radios nowadays do not use a potentiometer, they use a rotary encoder for volume control.
This is true, my post was wrong to call it a pot, but the inherent weakness and lifespan is the same. Friction wears down contacts.
Old Dec 9, 2011 | 03:41 PM
  #42
second4s's Avatar
Problem with rotary encoder
I am have been having the same problem with the volume control in my 1998 nissan maxima bose stereo. Recently, I was attempting to remove the ****, but the entire rotary encoder came out. I was wondering, can anyone provide a link to where to buy these? Are they universal, if not, could pick them up at an electronics store? Thanks in advanced!
Old Dec 12, 2011 | 09:15 AM
  #43
Nopike's Avatar
FWIW Rotary Encoders use glass and light to function. There are no contacts so no friction. They work similar to the laser sensor on your garage door that determines if some thing is in the way. They can fail regardless from vibration, stress or environment.
To the guy loking for the part.
CLARION 016001001 CONTROL VOL
http://www.pacparts.com/model.cfm?mf...de=auto&back=0
Old Dec 12, 2011 | 01:27 PM
  #44
second4s's Avatar
I was looking for a cheaper substitute than the one already mentioned, but, that's okay, I figured it's only $20 which is much cheaper than a new hu. Or even an aftermarket, which isn't promised to have the same sound quality. I will be receiving this part on Wednesday and will attempt to repair it the same day. I will let everyone know how it goes! Thanks for everything!
Old Dec 12, 2011 | 03:04 PM
  #45
ShocknAwe's Avatar
Bose makes really good stuff and if you don't want to replace it I don't blame you. However, Bose stuff is really expensive to repair or fix and if you don't know what your doing you will surely do more harm than good. I did an install the other day on an audi A4 where a speaker had blown. The mounting bracket for it was an off size and the speaker itself was more than aftermarket ones you would get on Crutchfield. No other modern bracket would be able to screw in the door and hold even the most popular sizes of speakers. My advice to you would be to take your HU out and check it out. A wire could have got snagged or a connection could have broken on the board. A simple fix to both but you wont know the problem until you take it off. Do you know how? If not say so and I can walk you through it. Ive taken apart so many 4th gens its not even funny. hope this helps.
Old Dec 12, 2011 | 06:42 PM
  #46
Nopike's Avatar
It's not hard to change if you have a soldering iron, solder sucker and solder wick and know how to use them. If not it may be worth paying someone a few bucks to replace it for you. The volume control failing is a common problem and this is almost certainly the part at fault.
Old Dec 14, 2011 | 11:49 AM
  #47
rrg's Avatar
rrg
You guys still need that bose. I have one 1997 with no preset buttons.
Dirt cheap.
thx.
Old Aug 22, 2014 | 07:01 AM
  #48
ronnybolt's Avatar
Latest part number for volume control
Pac Parts, INC. 800-421-5080
Clarion #930783778778
$8.36
Soldered it in and now it works like brand new!
Old Aug 22, 2014 | 08:00 AM
  #49
max-nutcase's Avatar
Im sure the OP will appreciate the info!!
Old Aug 22, 2014 | 08:11 AM
  #50
Fakie J Farkerton's Avatar
You got that right.
2010 wasn't a year that made it easy to find information.
I'm sure OP has been waiting 4 years for an answer.
Old Aug 22, 2014 | 10:16 AM
  #51
surban1's Avatar
the OP may not care any longer but anyone experiencing issues with their volume control **** (like myself) is probably glad to have an actual part # to refer to. so, at least from me, kudos to the newbie for contributing something worthwhile and of value.
Old Aug 30, 2014 | 12:06 PM
  #52
99zx2's Avatar
amen to that. yes, i'm the op lol
Old Aug 30, 2014 | 12:57 PM
  #53
Old Aug 28, 2018 | 02:02 PM
  #54
nissan99's Avatar
Originally Posted by ino20
mine did that before i bought my aftermarket head unit. i sprayed it with some eletric applience cleaner and it went away for awhile
I got a 99 Maxima where the volume would stay high and loud and when I set it to low it would be no sound .. I turn it up and plays loud .. so will this be a way to fix it
jdstud412
Dec 23, 2006 04:29 PM
DoGGy
Sep 14, 2003 03:19 PM
Str8ridin
Jan 25, 2003 10:54 PM
