Swirl Valve Questions
Old Jul 22, 2010 | 02:25 PM
DTrem08's Avatar
Well, I got the P1130 swirl valve solenoid CEL the other day. This is the second time its happened in 2 years. The first time I paid to have it fixed and I cant afford to do that again. I'm good with working on cars, but theres a problem....I have no clue what part I need to replace. Through searching, I've read that you can disconnect and plug one of the vacuum lines to prevent the valves from working or whatever and I think thats what I want to do so I dont have to deal with this again.
Heres a picture of where I think the swirl valve and all the related lines are located, but I could be wrong. If someone could tell me what I have to disconnect/plug/replace, that would be amazing as I;m due for an inspection!
Old Jul 22, 2010 | 02:34 PM
eFLO's Avatar
youve got it. but even if you do unplug and cap the vacuum line you'll still have a cel.
Old Jul 22, 2010 | 03:42 PM
DTrem08's Avatar
What part needs to be replaced to clear the CEL?
Old Jul 22, 2010 | 05:43 PM
Spyguy's Avatar
You don't need a part to turn it off. You will need an OBDII scan tool to take it off. Just ask Autozone to turn your CEL off for you.
Old Jul 22, 2010 | 05:56 PM
schmellyfart's Avatar
The CEL will more than likely come back if the solenoid is still broken.
I think you stated the that needs to be replaced in your first sentence, the swirl valve solenoid.
Old Jul 23, 2010 | 07:13 AM
njmaxseltd's Avatar
That picture shows the swirl valve vacuum actuator.
You need to find the electronic solenoid, which is the switch that puts vacuum to the actuator valve in your picture.
Old Jul 23, 2010 | 09:00 AM
fat_kid's Avatar
follyburr
Detailing
Jun 13, 2016 02:06 PM
trailer54
Nitrous
Nov 18, 2015 07:44 PM
Max139617
Sep 20, 2015 07:25 PM
bumpypickle
Sep 20, 2015 08:22 AM
tardrex
Sep 11, 2015 07:35 PM
