can those w/AT help me out (very simple)
Old Jul 24, 2010 | 10:10 AM
cdmapro's Avatar
with engine off, key on all the way (but not cranking) press down on gas pedal. do you hear a buzzing sound coming from the auto transmission? sounds like a relay or solenoid "chattering". when you're under the car the noise seems to come from directly inside the pan, near the front end of the tranny. goes away when you take foot off gas pedal.
I just noticed this while troubleshooting hard warm start problem.
Old Jul 24, 2010 | 07:41 PM
ajm8127's Avatar
Interestingly enough, I've noticed a similar noise coming from my AT. I had the ECU harness unplugged while I was installing my wide band O2 sensor. I also had the key in the on position in the ignition. Not sure if the ECU harness had anything to do with it, but I thought I'd mention it.
Old Jul 24, 2010 | 07:48 PM
MAXIMA_STYLE's Avatar
well i would imagine if it was inside the pan it would be a sensor or some sort i dont think there are any relays in the pan itself
Old Jul 24, 2010 | 08:54 PM
99zx2's Avatar
there's a valve body with all sorts of solenoids on it. google your symptoms, and i bet you'll find something.
Old Jul 24, 2010 | 09:28 PM
aterfy27's Avatar
Interestingly enough, this same thing happens on two other cars my family has, but it has never been a problem...One is a Chevy and the other is a Honda..
Old Jul 25, 2010 | 04:52 AM
max ride 41's Avatar
ha!!! isnt this supposed to happen??? i mean, there's a selenoid that cranks on when you turn the key, amiright???
Old Jul 25, 2010 | 02:57 PM
aterfy27's Avatar
that would definitely seem feasible...
Old Jul 25, 2010 | 07:07 PM
cdmapro's Avatar
no. let me clarify the situation. engine off, not cranking, key on. I'm not talking about the starter or starter solenoid.
with key on, engine off, not cranking, can someone please verify if they hear a buzzing coming from auto trans when they press on gas pedal (again, with engine off)?? then the buzzing goes away when you lift off the gas. you will have to be in a fairly quiet environment to hear it.
Old Jul 26, 2010 | 06:07 AM
maxed_out_99's Avatar
ill check this out on my way home from work today. im willing to bet its a wot solenoid engaging im sure when to go to k.o.e.o. it engages the shift solenoids.
Old Jul 27, 2010 | 04:28 PM
cdmapro's Avatar
anyone able to check this out on their car? on mine the buzzing happens at any throttle position beyond closed.
Old Jul 28, 2010 | 11:11 AM
Capitone's Avatar
Interesting....I'll check this out now. Be back in a few.
Old Jul 28, 2010 | 11:21 AM
Capitone's Avatar
Ok, gave it shot. Key in ignition, turn to "on" position. Tapped peddle.
Verdict: if there is a noise, it certainly isn't loud. That said, I feel as if I heard a sort of faint electric buz when I pressed the gas pedal down. I can't say for sure because there was some residual noise way off in the back ground where I work so it was hard to tell, but like I said, if there is a sound, it isn't very loud at all.
I may try this again somewhere quiter out of curiousity. Hope that helped.
Capitone
Old Jul 28, 2010 | 02:49 PM
RA030726's Avatar
I'm nutty for Nissans
Yes I remember such a noise on my old car.
Old Jul 28, 2010 | 09:10 PM
midnight0045's Avatar
i'm fairly certain this noise is normal. happens to mine if you listen close
Old Jul 29, 2010 | 10:03 AM
alright well i checked mine and all i heard was a faint click i think you got a solenoid takin a sh**
9aj9
Apr 5, 2020 12:11 AM
Mahmuth
Sep 25, 2015 10:08 AM
meccanj98
Sep 17, 2015 08:28 AM
ac max 92
Sep 17, 2015 07:35 AM
meccanj98
Sep 16, 2015 06:06 PM
