Yet another s-afc question
Old Jul 25, 2010 | 06:52 PM
K31J1m0N's Avatar
for some reason the ground and power wire for my ecu isnt booting up my afc...i wired it up to my battery to make sure it wasnt a defecting afc and it turned right on... now im assuming if the ground or power wire were bad then the ecu wouldnt turn on..now my question is is it ok to wire and ground my afc to another power source and ground or will that cause a problem down the line
Old Jul 25, 2010 | 07:02 PM
NmexMAX's Avatar
dot dot dot ...
I used my cig lighter wiring. Maybe add an extra ground to your ECU and see if that helps.
Old Jul 25, 2010 | 07:12 PM
K31J1m0N's Avatar
ill give it a try...has it given u any problems and how long have u had it wired to your ciggarette lighter...im not sure if it s a rumor but i heard u shouldnt wire it to a source other than the ecu power and ground wire
Unclejunebug
Apr 2, 2016 05:42 AM
Stagnet04
Oct 11, 2015 08:16 PM
Socalstillen
Sep 26, 2015 12:01 PM
