Coolant leak from thermostat housing or engine block drain plug?
I've replaced all my hoses, my radiator and my water pump on my 98 SE 190K 5 speed.
Last week I found a dribbling leak that looks as if it comes from the AC Compressor near the oil pan but if you trace it out actually emanates somewhere higher in the thermostat area. I tried a pressure tester, but that actually stops the leak.
This week the leak is very evident so my car is off the road and tomorrow I start disassembly. Am I right in thinking it's either the thermostat housing or the block drain plug which is in the same area?
Finally--this doesn't have anything to do with the water pump change out does it? If that leaked, I would have coolant in the oil which I don't have.
yes but the water pump is totally enclosed
yes but the water pump is totally enclosed so if water was coming out the weep hole you would never see it as a puddle on the ground?
Thanks for your help!
The water pump has a weep hole that has a passage in the timing cover to let you know that it is bad. If it is leaking on the compressor and thermostat housing, your water pump is bad.
Could very likely be the upper water neck. I had mine start to leak in the same area you described and at right around the same mileage as yours is now. It's an easy and cheap fix so you might want to just change it out..
Check this out..
http://www.courtesyparts.com/maxima-...1808_1811.html
You need this...
http://www.courtesyparts.com/13050p-...-p-130201.html
And while you in there you mine as well replace the housing with the thermostat that is pre-installed in the housing. When you buy it you will get the whole housing like how the first link diagram shows it. Not just the thermostat in the individual picture.. Amazing they only charge $20 for this piece..
http://www.courtesyparts.com/21200-t...-p-130206.html
Check this out..
You need this...
. Good wrenching my dude.
Question about this problem
Hello,
I've been lurking and using the advice from this forum for several years and it has been immensely helpful. I have a coolant leak on my 98 similar to the one described here, and in a few other threads. It is small at this point, and shows up on the edge of the lower oil pan. I've had the splash guards off and looked everywhere I could to see if I could trace it back, but even after cleaning everything and letting it sit I can't really get a good trace on it. I can tell that it is not coming from thermostat housing, or any hoses that are visible. It does look like it could be running down in between the upper oil pan and the engine, but it is really hard to see in there without taking off the air conditioner compressor or the oil pan. From everything I read it sounds like this is consistent with the gaskets on the water pump going bad, but before I dig into that repair I wanted to see if there were any other places that I should be looking that don't require more time than replacing the water pump. thanks.
Hello,
conansriver
Sep 3, 2015 06:38 AM
raffivegas
Aug 23, 2015 09:54 PM
