my rotor is glazed!
my rotor is glazed!
I did some research and believed that one of my rotor is glazed. Right now the whole rotor ( rear passenger ) is covered by substance that looks like rust. I can occasionally hear dragging noise from the passenger side when I drive and when I let go of the brake pedal. My question is what is causing the glaze? And how do I resolve this issue without replacing the rotor and the pad. The rotors are brembo blank replaced 5 years ago and the pads are 3 years old. I need some feedbacks please.
and you'll notice some drag as well as poor MPG
Your pins are rusted "open" dis-allowing contact between rotor and pad, and allowing rust to build up on the outer surface of the rotor. Your inner pad is likely still making contact and producing SOME work.
I'm going to take a look and maybe lube it up. If it fails, can I just buy the pins or I need to replace the whole caliper plus the bracket?
Rust and glaze are 2 opposites. Rust, which is dull looking, red and fuzzy, happens when the metal it not being rubbed by the brake pad. Glaze is very shiny and happens when the brake pad rubs the rotor so hard and long that the rotor gets extremely hot (overheated) which may make the rotor a bluish color.
You may be able to clean thaem and then lube. Try rolling sand paper up and sticknig in the bore, beyond that maybe a gun bore brush .38 or 9mm oughtta be close, maybe a lil big.
I think my rears may be frozen are they supposed to spin completely freely because I'm able to spin them but then they stop and they are hard to get past a certain point on the rotor it seems then they spin easily if I turn them past that point
Your rotor is warped, causing the brakes to be tighter in one spot, The fronts can do the same thing as well as be un-parallel. A sticking caliper would compound the problem, but is not the primary concern in your case.
The rotors can be a little bit warped and not cause any problems. Spinning the wheel by hand is not an easy way to tell if you have a problem. On many cars the wheel does not spin freely and always stops in one spot. Driving and stopping will tell you more.
if there is ANY rust in the pad contact area of the rotor, you have a warped rotor. A rotor that is being used and isn't warped will always be shiny.
If the wheel cathes slightly in one spot, it is not a cause for alarm, but a strong catch + rust on the contact area of the rotor = warpage.
Apr 16, 2020 05:15 AM
