need recommendation on door lub
Old Jul 30, 2010 | 05:58 PM
joew's Avatar
i have been using the PB blaster to lub car doors. it works for about 6 weeks. any recommendation?
Old Jul 30, 2010 | 07:17 PM
Br0nz's Avatar
white lithium grease works great does not attract dirt clean with pb let it dry apply then wipe extra off
http://www.ehow.com/how_2083717_use-...um-grease.html
something like this is fine:
http://www.amazon.com/gp/product/B00...7R5DCZADB006DV
Old Jul 30, 2010 | 10:43 PM
DennisMik's Avatar
white lithium would be a good choice. What you learn over time is that things like PB Blaster and WD40 are not lubricating oils. They are a bunch of chemicals for penetrating into tight spots and getting them free. You should always use oil, grease or whatever is appropriate after you free something up with PB Blaster or WD70.
Old Jul 30, 2010 | 10:55 PM
nelledge's Avatar
"I'm just sayin'..."
Originally Posted by Br0nz
white lithium grease works great...
Old Jul 31, 2010 | 05:24 AM
max ride 41's Avatar
wtf is lub??? ITS LUBE.......
Old Jul 31, 2010 | 05:26 AM
Br0nz's Avatar
lol.
...no homo
Old Jul 31, 2010 | 11:39 AM
iDuty's Avatar
I agree that WD-40 and PB-Blaster aren't good lubricants.
Good luck getting any white lithium grease into the hinges where it is needed. In my experience it only makes a mess around the problem, but doesn't penetrate to where it is needed.
I find that a light creeping oil works for hinges. Put a drop or two where gravity plus the oil's attraction to metal will get it into the hinge.
Old Jul 31, 2010 | 12:03 PM
shadetreemech77's Avatar
don't know the guy, but he said exactly what I've discovered to be the truth.
I generally save my used motor oil, and if you don't mind a bit of clean up, it works great to keep the hinges oiled. Plus it's free.
Old Jul 31, 2010 | 12:33 PM
DennisMik's Avatar
For the door hinges, I like to use auto trans fluid. It can creep its way into tight spots. For the bar that holds the door open, white lithium would work as well as other types of lube.
REDinLV
Aug 15, 2024 12:30 AM
magiconthetire
Oct 26, 2015 09:03 PM
MaxLvr21
Oct 17, 2015 12:11 PM
BobTX10
Oct 7, 2015 08:43 AM
DC_Juggernaut
Sep 28, 2015 04:07 PM
