Keylessride remote wont program.
Old Aug 1, 2010 | 05:44 PM
tiresmokinV8's Avatar
Well I picked up a keylessride remote for my 96 max since I didnt get any remotes with it when I bought it last year. I can get the hazards to flash when inserting the key into the ignition 6x. but then when I turn it to acc and press the lock button on the remote nothing happens. The led on the remote flashes but the hazards dont. Also sometimes it doesnt take 6 inserts into the ignition to get the hazards to flash. Its done it on 3, 4 and 6 insertions? Whats the problem?
Old Aug 2, 2010 | 08:55 AM
oldngivout's Avatar
Willing to learn
Maybe you have the wrong remote? I don't recall any factory remotes having visible LED's.
Old Aug 2, 2010 | 10:48 AM
DennisMik's Avatar
You may have 2 problems. 1- a flakey ignition switch [sometimes it doesnt take 6 inserts into the ignition to get the hazards to flash. Its done it on 3, 4 and 6 insertions] and 2- the remote may not be the correct one for the car. The FCC id for the remote should be stamped or molded into the remote's case. The FCC id for a 97 Max is A269ZUA078 which I think is the same for all 4th gens.
Old Aug 2, 2010 | 11:37 AM
Guess Ill have to call them up and ask. my remote FCCID: SRW-KRVAR001 its a keylessride branded remote.
Old Aug 2, 2010 | 12:00 PM
Well as far as I can tell the remote they sent me is the correct aftermarket remote for me.
Old Aug 2, 2010 | 10:33 PM
myblzurchn's Avatar
I have to aggree with Dennismik & oldngivout, about having the incorrect remote. It sounds like you may have been sold one from an aftermarket alarm system that will probably not work with the stock keyless entry/ alarm. I also just ordered a new fob off eBay actually got it for $11 and change and it works great.
Old Aug 3, 2010 | 12:28 AM
Ill have to call up keylessride.com tech support when I get back from my trip but I was looking through posts on keyless remotes and found a thread on keylessride and the remote that user used has the same fccid as the one I recieved.
Old Aug 3, 2010 | 06:23 AM
Remminator's Avatar
I got the same issue on my 95, I'm using oem remote.
Old Aug 3, 2010 | 12:26 PM
Fatboy98maxima's Avatar
i have 2 remotes oem for sale
Old Aug 3, 2010 | 02:08 PM
Remminator's Avatar
Anyone know a way to test oem remote without usin the car?
Old Aug 4, 2010 | 03:18 PM
BiRd DaWgY's Avatar
Does anybody have a manual for the OEM one i have one but it died and id like to replace the batteries and find out what all it can do
Old Aug 5, 2010 | 12:55 AM
gunitsolja's Avatar
Mine acted funny when I was programming it to but after a couple of frustrating tries it worked. Keep trying and if not Jus grab one off eBay like the other guy said I got 2 oem ones for 20 shipped
Old Aug 13, 2011 | 01:21 PM
rdlf4's Avatar
i have the same prob. with my remote. cant get it to program I have 2 aftermatket. one is working properly. fcc id:elvmtbb. its a carbine remote. I feeel my ignition cylinder is bad, have to play with it some times to turn it on. I will get a new oene before I discard the remote
ToTheMax305
Sep 23, 2015 09:11 PM
flu2000
Sep 14, 2015 12:34 PM
intimidator
Sep 5, 2015 07:23 PM
trungg86
Sep 4, 2015 04:58 AM
