Magnaflow Y-pipes
Old Aug 5, 2010 | 07:56 AM
cashoit's Avatar
Magnaflow Y-pipes
I was on the magnaflow webiste and stumbled upon this:
http://www.magnaflow.com/02catalytic...irectfit=27503
Overpriced? hmmm, i think so lol
Jus thought i share.
Old Aug 5, 2010 | 08:05 AM
95Maxed's Avatar
LMAO, I wonder if thats a mistake or for real
Old Aug 5, 2010 | 08:13 AM
kiecas17's Avatar
Its $561 here
http://www.performanceexhaustplus.co...-assembly.html
I'm guessing people are going to start buying these if they don't like how loud the other y-pipes are.
Old Aug 5, 2010 | 08:22 AM
cashoit's Avatar
Originally Posted by kiecas17
Its $561 here
Wowwwww. 900 bucks just slashed off. Good find
I saw that $1500 price and was like i can buy a used engine AND tranny for cheaper
modenaf1's Avatar
I don't see why anybody would buy this. This is an OE replacement with the pre-cats. If you want to keep your precats for whatever reason, there are plenty of used stock y-pipes sitting around that nobody wants anymore.
Old Aug 5, 2010 | 12:56 PM
This.
Old Aug 5, 2010 | 01:01 PM
aackshun's Avatar
Maybe they flow better? lol.
Old Aug 5, 2010 | 01:43 PM
beegeezy's Avatar
Probably cheaper than a new one from the dealer...if they even sell it anymore.
Old Aug 5, 2010 | 03:43 PM
Br0nz's Avatar
if you didnt know any better... precats are still cats hence $$$!!!
Old Aug 12, 2010 | 11:13 AM
Racing Nissans's Avatar
Pre-cat is only used for cold start emissions while the main cat is heating up. Unless it is required in your state, do without them and gain hp & mpg, reduce under hood heat.
Old Aug 12, 2010 | 06:17 PM
RA030726's Avatar
I'm nutty for Nissans
Selling and installing used cats is illegal. A shop needs new parts from some where.
Old Aug 13, 2010 | 02:30 AM
99greddymax's Avatar
in cali it's illegal to buy and sell used cats. The only people who buy cats are metal scrappers(big $$). Also pre cats do go bad, this is a good replacement. There are still ton of maxi's out there, and most of them are stock.
Old May 25, 2018 | 08:07 PM
maximaxi's Avatar
The price is around $400-500 now.
The main advantage of the Magnaflow Y-pipe is that the mandrel-bent pipes while still keeping the pre-cats.
Other standard OE replacement aftermarket front pipes/pre-cats use the stock crush/crinkle bending. Just like the original one that came with the car.
Old May 26, 2018 | 09:35 AM
CS_AR's Avatar
You can get a new Warpspeed y-pipe for $275. Just scroll down to the 4th gen section.
I've purchased 4 WS y-pipes over the years. They always fit perfectly..
http://www.warpspeedperformance.com/...ti_i30_y_pipes
Old May 26, 2018 | 06:00 PM
maximaxi's Avatar
That WS y-pipe doesn't have the pre-cats. The Magnaflow y-pipe does.
Old May 27, 2018 | 10:15 AM
max ride 41's Avatar
that's the whole reason i got my warpspeed y-pipe?? why would you want the pre-cats unless you were running a stock exhaust.
Old May 29, 2018 | 12:10 PM
maximaxi's Avatar
The whole reason is that the stock y-pipe has the crush/crinkle bends which constrict exhaust flow and cost power (plus, they rust after a few years).
The Warpspeed Y-pipe uses mandrel bends, as does the Magnaflow (and also the now-discontinued Cattman)
Modern cats (and pre-cats) do not rob any power.
Old May 29, 2018 | 03:11 PM
wachman's Avatar
Im confused. Does the Warpspeed y-pipe fit up to a stock exhaust or not? Thats what I thought i read from the website...
Im thinking about pulling the trigger on one. My flex pipe is looking pretty bad and noisy as hell. I figure i should go for it instead of spending the money on a cut and weld for a new flex
Old May 29, 2018 | 05:09 PM
maximaxi's Avatar
The Warpspeed fits perfect, but it doesn't have the pre-cats that come on the OEM pipe. So if your car is subject to emissions testing/inspection, you will automatically fail the visual "tampering" inspection.
Now, if you live somewhere that doesn't have inspection, you can probably get away with the Warpspeed. Removing a cat (including pre-cats) for any reason other than its immediate replacement is illegal in all 50 states (federal law), but you probably won't get caught or fined or anything if your state doesn't do inspections.
Old May 29, 2018 | 05:14 PM
wachman's Avatar
Luckily for me, Jersey's inspection is a joke. They just do emissions no visual. I once went through an inspection station with a cavy z24 without a working parking brake, and the driver door was caved in and inoperable due to an accident prior. Couldn't believe i passed.
Old May 29, 2018 | 05:17 PM
maximaxi's Avatar
Luckily for me, Jersey's inspection is a joke. They just do emissions no visual. I once went through an inspection station with a cavy z24 without a working parking brake, and the driver door was caved in and inoperable due to an accident prior. Coulsnr believe i passed.
That's because NJ is emissions-only
Quickywd01
Sep 21, 2016 09:36 PM
Justin Kroll
Oct 1, 2015 07:03 PM
lrb6805
Sep 17, 2015 04:49 PM
Violator
Sep 9, 2015 10:14 AM
