quick caliper install question
Old Aug 7, 2010 | 04:56 AM
cdmapro's Avatar
so the two caliper slide pins (front) - one of them is solid steel, the other has a rubber end. they are same length. which goes where?
also, when installed the caliper should have enough room to slide 1/8" or so on the slides, right??? why are the friggin autozone calipers too big? there's not enough room for them to slide in the caliper bracket - this will cause the brake to hang/stick, right??
Old Aug 8, 2010 | 04:04 AM
najee1062's Avatar
AZ caliper are a piece of crap... Take them back if you can and rebuild you original ones... or buy calipers from somewhere else.
JRod28
Dec 29, 2023 09:56 PM
Matt93SE
May 24, 2019 02:58 PM
rbuswell
Nov 17, 2016 04:54 AM
Cant_Get_Ryte
Aug 28, 2015 06:41 AM
RealityCheck
Aug 5, 2015 06:18 AM
