Car Won't Start
Old Aug 17, 2010 | 06:42 PM
il99max's Avatar
Car Won't Start
So, I didn't drive my car for 2 weeks. Went to start it today and when I try to start the car it makes a loud metal on metal noise like I'm trying to start a chainsaw. Car won't even attempt to turn over. Anyone know what would cause this?
I thought it was the starter so took the old one to Autozone and got my free lifetime replacement. Installed it and it still makes the loud, metal whirring noise. Even bought a ground wire and ran it from one of the bolts on the starter to the negative battery terminal close to the battery tray. Still does the same thing.
Some other people are thinking may be some of the teeth on the fidanza flywheel are damaged and may be causing this.
Old Aug 17, 2010 | 06:50 PM
96sleepergle's Avatar
Its your flywheel those Fidanza flywheels are weak, I went back to stock. Had the same problem your having ,thought it was the starter but when i took the starter out put my hand where the flyweel ring is a it spun around took the flywheel out and the the bolts that hold the ring were loose.
Old Aug 18, 2010 | 03:34 PM
il99max's Avatar
Good call on the Fidanza flywheel 96sleepergle. I removed the cone filter and midpipe and stuck a flashlight in the hole. Upon further investigation, 3 of the flywheel teeth are broke.
Old Aug 18, 2010 | 04:07 PM
beatdown97's Avatar
heres a decent priced one thats new .. i saw a bunch from ebay ranging from 20 bucks to 60 but thats for a used from ebay, then theres this one http://www.oehq.com/acdelco-parts_388117_ACD_ACDelco%20Engagement%20Flywheel~1 997%20NISSAN%20MAXIMA%20SE%203.0L.htm
Lakersallday24
Jun 16, 2019 01:35 AM
kjlouis
Nov 24, 2018 06:09 AM
Btheman80
May 1, 2018 04:03 PM
MAXSE5SPD
Aug 23, 2015 12:06 PM
BobMax
Aug 15, 2015 12:35 PM
