ac vent question..
Old Aug 21, 2010 | 06:08 AM
99greddymax's Avatar
ac vent question..
Hello,
I have a small issue with my ac vents. I get buku amounts of air coming from the far driver side, and far passeger side. However i hardly get any air from the center vents with the fan in full blast.
Any ideas?
Old Aug 21, 2010 | 06:54 AM
Br0nz's Avatar
have you ever taken your dash apart? maybe you cripped the vent behind the center console?
Old Aug 21, 2010 | 07:51 AM
atriuum's Avatar
Check the FSM
Look at the FSM HA-21. There is a troubleshooting section for the control module not operating the way it should, which lists potential causes and solutions. I'd start there.
Old Aug 21, 2010 | 07:49 PM
Atimaxx's Avatar
Could be as simple as one of the levers that controls opening and closing the vents, usually you can access them from directly under the dash. The FSM should show you what to check.
Old Aug 23, 2010 | 02:14 AM
i guess im not explaining the problem correctly. when the floor, face, or defrost is selected, everything blows where it supposed to.
However when face is selected the center console vents dont blow out as much air as the far pass, and far driver side.
I checked the fsm, however there's nothing regarding this problem.
Miket2006
Mar 1, 2021 03:55 AM
t6378tp
Sep 29, 2018 04:27 PM
Smackasmith
Feb 1, 2016 12:40 AM
spidgeon
Sep 9, 2015 03:36 PM
