Shimmy at about 80-85
I dunno if this should happen or not but at about 80mph i get a slight shimmy in the steering wheel...it's an on and off thing...sometimes up in the 90s there is no shimmy....could it be mounts or what?....any help/
Re: Shimmy at about 80-85
-V
haynes repair manual is your friend steering wheel vibration is caused yes by tires which if you rotate will fix the problem if that dosent fix it it could be a loose or worn wheel bearing , worn tie-rod ends, or worn lower balljoints
Re: Re: Shimmy at about 80-85
Originally posted by vmok
Try rotating the tires from the front to the rear and the rears to the front. An unbalanced tire/wheel assembly can cause the symptom you're talking above. If that eliminates the problem, bring your car in to a tire shop and have them do a dynamic 4 wheel spin balance.
-V
-V
Check.
02nissmax
09-05-2015 01:50 PM
mattman2003
09-19-2003 02:43 PM
