Rear beam re-alignment question
Old Sep 8, 2010 | 01:49 PM
QnzMax's Avatar
Hey guys, I just finished re-aligning the rear beam on my 5.5 and I want to do my brothers as well. He has a 4th gen and it looks a lot different under there than the 5th gen. Besides the fact that everything is in front of the beam (which is a PITA), which bolts do I loosen? Here's some pictures facing the back of the car:
I would assume its this one:
(Passenger side)
And the one on the far right closest to the wheel:
(Driver side)
Old Sep 8, 2010 | 02:58 PM
asand1's Avatar
There is no alignment adjsutment in 4th gen, If the axle is off-centeror sloppy, replace bushings.
Old Sep 8, 2010 | 03:34 PM
ampire's Avatar
Seriously?
Because I was just about to start the same project based upon recommendations in the Advanced Suspension forum. http://forums.maxima.org/advanced-su...rear-beam.html
Well at least I won't waste my time trying it, however I was really hoping to fix my rear toe problems.
Old Sep 8, 2010 | 04:58 PM
DIAMONDS98SE's Avatar
Originally Posted by ampire
Seriously?
I as well have these rear toe problems. I was worried about if for a week or so, but the car drives fine, little pull to the right. But i dont see any irregular tire wear so i figure not to wirry
Old Sep 8, 2010 | 06:09 PM
Trini Boom's Avatar
What bushings are you referring to? The sway bar link and the lateral link??
Old Sep 8, 2010 | 07:08 PM
asand1's Avatar
I was referring to the lateral link bushings and the front pivot bushings as well.
The link posted above does have some merit as it will take the bind out of the bushings and allow freer movement, however it won't change toe or camber, only axle bending will.
Old Sep 8, 2010 | 08:22 PM
QnzMax's Avatar
I was under the impression that you were able to do this on the 4th gens. Guess I was wrong. Thanks for the clarification guys.
incubusjohnny
Nov 3, 2015 05:18 PM
Huttig2009
Sep 25, 2015 03:31 PM
JoshG
21
Sep 4, 2015 09:04 PM
delerium75
Aug 19, 2015 11:08 AM
YourLocalAsian
Aug 17, 2015 02:33 PM
