Alarm System Cuts Off Fuel?
Old Sep 9, 2010 | 07:06 AM
KyleFort32's Avatar
is it possible that my alarm system is messed up... ive checked everything fuel pump fuel filter all the sensors new starter new battery... the car will start with ether then it will die out.... is there any way i can reset the car alarm that is cutting off fuel.. is that even possible?
Old Sep 9, 2010 | 07:21 AM
KyleFort32's Avatar
i need to reset my alarm im pretty sure any one know how?
Old Sep 9, 2010 | 07:29 AM
riseanew's Avatar
What year is your car? I had a similar problem a few months ago and it turned out that my immobilizer just died on me. Nissan introduced the immobilizer in Maxima's in 1999 as an anti-theft device. (Read more about it here) It sits underneath your dash, on the right hand side of the steering column. It's a black plastic box about 2"x3" and is attached via a metal bracket. It was manufactured by Siemen's and is virtually impossible to get in the after-market. You can buy a new one from the dealer in the $400 range. I shopped around local salvage yards and finally scored a working unit on my 3rd try. The best part is they only charged me $20. It worked fine after that. Hope this helps. Good luck.
Old Sep 9, 2010 | 07:43 AM
KyleFort32's Avatar
its a 1999
Old Sep 9, 2010 | 09:13 AM
asand1's Avatar
Have it towed to dealership. Immobilizer has amnesia and needs to be reprogrammed to recognize your key. If you had a second key copied its what triggered your problem.
Old Sep 10, 2010 | 12:17 AM
ef9's Avatar
ef9
Are you serious? The Maxima came with a fuel cutoff for the alarm? I only thought the G4 and G5 Clifford alarms had this type of immobilizer.
Old Sep 10, 2010 | 08:54 AM
colombianmaxima's Avatar
What alarm system is it bc some docut offfuel if u still need help pm me I do alarms n **** for a living
Old Sep 10, 2010 | 09:01 AM
asand1's Avatar
As far as I know its not an alarm, just immobilizer. If the security light stays on with the ignition on, your car is disabled and won't start. The immobilizer is feature of the factory nissan security package and may be unique to the 99 model year and later Gens. There are numerous threads discussing it.
Old Sep 10, 2010 | 10:19 AM
aackshun's Avatar
According to your profile your car has the infamous immobilizer, so do i and so does the OP.
As far as the problem @ hand.... Hrmm to the FSM!
Old Sep 10, 2010 | 09:23 PM
ef9's Avatar
ef9
So this immobiliser cuts the fuel? Or does it cut the starter?
Old Sep 10, 2010 | 09:26 PM
aackshun's Avatar
Fuel.
A starter cutout would be near useless on manual cars.
Old Sep 23, 2010 | 11:41 PM
99superblackmax's Avatar
So, is there any way to bypass this immobilizer? This has happened to me at least twice since the year and a half that I've had my 99 SE.
Miket2006
Mar 1, 2021 03:55 AM
Forge277
Jun 13, 2016 09:26 PM
zzznightmarezz
Sep 21, 2015 06:32 PM
